For Mike D., Kenneally, Brandon, Pat, Dave, Anton....and etc., etc., etc.
Here's a new one. Planned the new system around the Asus P5K Delux board (on compatibility list!). Got the board. Can exchange it - once! Weird situation. Intel P35 SATA RAID controller chipset will not allow single SATA System Drive and RAID 0 Video drives. Chipset sets only for one type -and ALL drives must be that type. Set to RAID, system drive must also be RAID configuration. Set to non-RAID, no drives can be RAID (onboard)! E-SATA is separate contoller.
Possible Solution # 1. Make the System drive an IDE drive instead of SATA, which is NOT controlled by SATA RAID controller. But before I do this, I must ask you guys one BIG question. While running EDIUS, how much does the program access the System drive on which the EDIUS program lies. If only the Video RAID drives determine the speed of EDIUS, then an IDE System Drive would not hurt performance. Yes?????
Possible solution # 2. Build a RAID array for the SYstem drive - which most of us (not all of us), feel is not worth the money and trouble. A "boot array" is a royal pain in the 'ars to configure.
Possible Solution # 3. The ASUS P5N32-E SLI board HAS an nVideo SATA controller on it - and that controller DOES allow a single SATA system HDD, and RAID HDD Arrays for other drives located "on computer" - such as removeable trays with 2 identical RAID Video Drives. BUT - this board is NOT on the campatibilty list, and thus, I'm a bit hesitant to swap the P5K board out for a P5N32-E SLI board, unless some of you know this board works with the DVStorm2 card.
I can only swap once, and if the P5N32-E SLI board doesn't work, I'm in deep doodoo! Don't know the difference between the PCI access between the
P5K and P5N boards - and I'm still using the DVStorm2 - as it still works quite well with SD.
I open this to the forum, and perhaps the responses might be of great value to all who are planning to build new editing machines with new technologies around the EDIUS NLE. Seems there are a lot of questions regarding motherboards, chipsets, video cards, etc. I will update all results as I put the system together,
Any thoughts? My thanks to all - as ever.....
Alan
Alan
