Hi Guys. Can I convert m2t to HQ avi on timeline. i tried editing with m2t directly and to my surprise it worked. However, upon export to dvd I can see the occasional hook up in the picture due to the m2t files. Whats a quick work around to this as I need to make the change quick. I need the m2t on the timeline in hq avi so i can export smoothly, will never use m2t to edit with again, silly me.
converting m2t to hq avi on timeline?
set in and out point and then click export button, choose Canopus HQ
I wonder how long before we need to call it GV HQAnton Strauss
I guess my question was a little unclear. I have m2t files on the timeline because I got lazy and did not convert them to hq before placing them on timeline. I have made a 1 hour video however any slow motion material does not export well in m2t format. I need the m2ts on the timeline in hq so that I can export smoothly. If I convert in bin then it makes a new file therefore forcing me to re edit everything. I hope that makes sense. i have been succeccfull this time, I removed slow motion trouble clips and even converted some of them into hq and re edited that part just to get this project out as time is a problem. Thanks again guys. I will always edit in hq for now on.
Are you sure the problem was the fact that they wern't HQ files? As far as I know, regardless of how CPU hungry a type of video file is, once rendered and exported, it shouldn't make a difference.
Were your "problem" slo-mo shots, pans by any chance?When I go out, I wear my EDIUS T-Shirt.
I forgot to mention a quick trick
1. be sure project setting render format is set to Canopus HQ
2. double click the ruler above a m2t clip with slow motion, this will mark in and out
3. press Shift+Q and the clip will become HQAnton Strauss
