Black Magic boards aren't supported in EDIUS, nor are they likely to any time soon.
Edius and BlackMagic capture card
Originally posted by andrew_hd View PostIt would be a nice option to capture HD footage to HQ codec in realtime (something like Premiere+Cineform).
Edius misses HD capture feature. Edius HD Desktop is to expensive when someone wants only capture footage and do only very simple edit.
Edius perfomance on 8 core PC is very good and it's a shame that we can't really use it for HD.
Andrew
George Dame - Grass Valley System Integrator - 10yrs.George Dame
Originally posted by andrew_hd View PostI have BlackMagic card installed on my machine. It's Directshow compatible.
When I've tried new Edius card didn't apear as a capture device. Why?
It works fine with other directshow capable software.
Andrew
If you capture in MJPEG codec through the Decklink card, you will be able to get similar RT performance in Edius. I have the Intensity Pro and capture in MJPEG or uncompressed and then edit within Edius.
Not a problem!Jerry
Andrew
Capture HDV straight from the camera to Canopus HQ on the fly from the firewire port and the quality is as good as from the camera.
Perhaps I need help in understading the above post
EDius Neo has the same capability
Bewildered Regards BarryWin 10HP, EDIUS WG9.4, HD Spark, Boris RED 5, VMW6, Authorworks 6, Bluff Titler, VisTitler 2.8, NEAT 3/4, Mercalli 2/4, Vitascene, Izotope RX6 Plugin, NewBlue, Trend Micro AV
Originally posted by andrew_hd View PostI've just checked Pegasus card.
Sounds good, but there is no timecode and no 1080p support. HD SDI to HDMI is not a problem, but I miss timecode and it looks that there is no way to have it (if I would like to recapture file I won't be able to it- start point will be different).
The best solution is to have Edius break the clips up as taken, each one has the time code on and work from there
Thanks Dave I knew I had to be missing something, I did not know of the HD, learnt something again from this forum, long may it last
Canopus HQ
Originally posted by Bluetongue View PostPerhaps I have missed something here, I use Edius without any capture card.
Print to DVD is fantastic.
Rick
Originally posted by ixlor8 View PostI have no problems with capturing 1440x1080P from Camera to Canopus HQ. The key is have a super fast computer. I am using a quad core.
Rick
I have a Canon HDV camcorder. The video is recorded at 1920 x 1080p directly to the camera. This video can be seen by the special HDMI Terminal. I capture the video by using the Firewire port which outputs the video at 1080i/60. I use the HDV capture in Edius and choose the right format to match the output of the camcorder. I use the CanopusHD choice. It produces a AVI files. Excellent quality.
Originally posted by Roy Colquitt View PostPlease, excuse my ignorance, but what recording format is 1440x1080p? Or are you capturing live camera output?
Regarding Pegasus - yes, it captures HDMI as Canopus HQ, but I would not regard it as an editing solution. Yes, it can be used in conjunction with EDIUS, but the workflow is pretty much like other third-party HDMI ingest solutions at present - capture separate and then import into EDIUS.
At present, EDIUS HD workstations are the only solution for the OP. While the RX-E1+MIP solution is only available within a turnkey from GV or a GV VAR in the USA, I think the story is a little different in the European market, and that you may be able to buy the hardware+software bundle outside of a PC. I suggest checking with the local office/distributor.
Originally posted by ixlor8 View PostI have a Canon HDV camcorder. The video is recorded at 1920 x 1080p directly to the camera. This video can be seen by the special HDMI Terminal. I capture the video by using the Firewire port which outputs the video at 1080i/60. I use the HDV capture in Edius and choose the right format to match the output of the camcorder. I use the CanopusHD choice. It produces a AVI files. Excellent quality.
1440x1080. You can capture through the HDMI connector through the Intensity to uncompressed or MJPEG 1920x1080.
The other Canons the A-1, the G-1, and the H-1 all record at 1440x1080 1.3 aspect but lack the HDMI output. The H-1 and the G-1, both have HD-SDI.Jerry
Cineform Aspect
Hi guys,
Does anyone know if you can get cineform aspect to work in edius? or do you just install it as a stand alone and use HD Capture to capture to a folder then import it to edius, with out Premiere installed can you still install aspect HD from Cineform or does it look for premiere when installing.
SteveMain system, Supermicro X8DAH+,Dual Xeon X5680 cpu's 24 cores,2x1400watt power supplys,SC747TG-R1400B-SQ Case,192GB 1333mhz ECC Registered ram,8 x 480GB Intel 520 SSD drives,Windows 7 64 bit ultimate, GTX 670 4GB ,2 x Sony BWU300S Blu-Ray burners, 1x Sony DVD burner,LSI 9266 Raid Controller with Cache vault & fast path Lic, ESI MayaE Audio,HD Spark,Blackmagic intensity Pro,TMPGenc 5,Episode Pro 6,Sorenson 9 Pro,Alcohol 120 V2, Edius 6.53,Dell 27"LCD,HD Spark, Powershield 3000VA UPS.
