audio background noise question
    Some decent VST plugins:
    http://www.modernplugins.in-tw.com
    http://www.kjaerhusaudio.com/classic-series.php
      Does Edius crash with these VSTs? When I started using Edius, I had maybe 20 VSTs and it would crash frequently. The Canopus fix was to remove all the VSTs, including SoundSoap. It never crashed after that. I have tried SoundSoap alone, even the 2.1 full version, and the preview skips and stutters badly and eventually crashes. It also crashed just having the VSTs in the Edius folder, not being used in the project. I'd love to find some VSTs that are not guarenteed to take Edius down. I currently take the audio out to Vegas, fix it up and bring it back to Edius.
      Main Edit Station: Edius 6.02, Gigabyte UD5, i7-950 @ 4.0, GTX 470, 12 GB GSkil, HD Spark, 4 TB RAID0 WD RE Video Drive, 2 TB RAID0 Render Drive
      2nd Computer: Edius 6.03, Asus P6X58D-E, i7-950 @ 3.07, Radeon 2600, 6 GB Corsair, 1.5 TB RAID0 Video Drive
        I don't know if anyone kept a copy of it, but the old forum had a thread where people posted VST plugins that were confirmed working in Edius. Sorry, but I don't have it. Anyone?
          i made a test last summer in the canopus forum with circa. 80 VST plug-ins in Edius 2.51. There was only one brand of VST plugs who did not appear in the list resp. could not open in Edius, that was the WAVES 4.0 with the L2 Ultramaximizer.
          here the list of the favorits:
          Voxengo GlissEq Vst, essential stuff at this site,
          probably the best pro plugs available today for a fair price.
          http://www.voxengo.com/
          T-RackS® Plug-in Analog Modeled Mastering Plug-Ins,
          very good EQ, compressor, limiter. This is my personal favorite.
          http://www.ikmultimedia.com/Main.html?IKInfo
          PSP Vintage Warmer, excellent maximizer! good prices.
          http://www.pspaudioware.com/indexen.html
          TLAudio EQ, warm EQ.
          http://news.harmony-central.com/Newp...berg/EQ-1.html
          Ohmforce PlugIns, far out stuff!
          http://www.ohmforce.com/HomePage.do
          GRM Tools Classics, special purpose VST's
          http://www.grmtools.org/quicktour/index.html
          this are VST .dll which can be copied from WaveLab direct to Edius plug folder:
          AutoPan.dll
          Choirus2.dll
          CleanComp.dll
          Externalizer.dll
          Grungelizer.dll
          Leveler.dll
          NaturalVerb.dll
          Noise Gate.dll
          Peak Master.dll
          Puncher.dll
          StereoEcho.dll
          StereoExpander.dll
          StereoSpread.dll
          StereoWizard.dll
          ToolsOne.dll
          just ask questions, i'm a audio engineer...
          this is the VST thread from last summer:
          http://www.canopus-foren.de/wbb2/thr...adid=5973&sid=
          Normalisation with VST plug-in is by pricipe not available. Normalisation is a offline render process. That means the WAV file gets processed that the loudest peak is 0.0 dBFs.
          The process to achieve more loudness with a VST Plug-In is Dynamics (Compressor/Limiter), sometimes called maximizing.
          Free plugs for maximizing in professional quality are:
          Classic Compressor by Kjaerhus
          http://www.kjaerhusaudio.com/classic-compressor.php
          Compressor Limiter Gate by mda
          http://www.mda-vst.com/
          __________________________________________________ ___________
          List of essential VST Plug-In types for Videowork (bold)
          Deesser to lower S in speech or voiceover.
          Dynamics (Compressor/Limiter) rise loudness, make dynamics compact.
          Limiter prevent clipping
          EQ to correct audio spectrum with eq filter.
          Exciter/Enhancer to artifically add upper range spectrum to dull sound.
          Mastering combi effect all in one (Eq/Compressor/Limiter).
          Noise Removal/Restoration
          Spectral Processor same as exciter/enhancer
          other VST plug-in types:
          Analyser Monitor
          Delay/Echo
          Distortion/Overdrive/Amp
          Filter
          Gate
          Imaging/Panning/Spatial
          Lo Fi
          Modulation (Flanger/Phaser/Chorus/ Tremelo)
          Multi FX
          Pitch Shifter
          Reverb
          Ring Modulator
          Tuner
          Vocoder
          Here is a huge list of avalable VST Plug-Ins, many are free:
          http://www.kvraudio.com/
          Home:
          >Instruments>Effects
          Quick Search: query
          Effects
          Dynamics(Compressor/Limiter) (for example)
          VST All
          Windows
          Free
          Note: VSTi (VST instruments) do no work with Edius. The VSTi are musical instruments made to use with sequencing software
          Version 2.51 does not work well VST plug-ins.
          I did test the VST plug-in back then with version 2.5 and 2.51. The progaming of the VST engine in Edius was not finished. The graphic of the opened plug-ins crashes and the program stands still.
          I can not tell you more, since i have not upgraded to v3.22 yet. I still use v2.51.
          Till Edius is capable for handling 24p and 23.976p, i have to use a other video application.
          I prepare all audio for video in WaveLab5 or Nuendo and re-import the fixed audio to the video applications.
          But sure, the fixing of audio in the video application itself is the future.
          WaveLab Lite: if you find the mentioned .dll in the folder you can copy them. Don't worry, if one dll is not compatible nothing will happen.
          In general VST .dll can be copied from other applications.
          The dll is the program. If they work, they appear in the list otherwise not, or a error message comes during start, nothing more.
          removing ambience is not possible. In case you wanna try anyhow, use a gate who closes on the reverb/ambience tail.
          One of the best pump up the volume VST plug-in is:
          L2 Ultramaximizer
          L3 Ultramaximizer or
          L3 Ultramaximizer
          from WAVES
          The advantage of this one is, it can look ahead in the data so no clipping can occour in case a strong peak is ahead.
          http://www.waves.com/content.asp?id=160
          http://www.plug-ins.de/bilder/10576.jpg
          a cheaper alternative is the Vintage Warmer mentioned above or any Compressor/Limiter
          ...all from Angelo
