Help Title Motion Pro pixel ratio
  • Help Title Motion Pro pixel ratio
    Hi everyone!
    I am a cutter working in Austria. We bought Edius as our new editing software.
    Version 4.5
    I use title motion pro as my standard titler. But after saving the title, it is in a different pixel ratio then my project. I have to change that for every single title in the clip options menu under still picture pixel ratio.
    Is there any possiblility to change the standard setting of the pixel ratio of the titles???
    Please give me a hint!!!
    Did you select the right project settings initially?
      Make sure you are running the latest version (4.54) - earlier versions of 4.5 had a bug with the title's aspect ratio.
        Thank you very much, after i installed the latest patch it worked!
          hmm, I still have that bug in 4.54 and it is confirmed by Mark Lampard (GV Australia)
          basically, when I open an existing 16:9 project, all titles have reverted to 4:3 and I need to scroll past the title with timeline cursor to make it pop back to 16:9, I need to do this for each title
            Are those titles created pre-4.54?
              yes and no
              it also happens in new projects
              1. start a new 16:9 DV or D1 project and add a title so it fills the screen side to side (to see the problem easier)
              2. close Edius
              3. open Edius and the above project and see how the title looks now
              4. scrub over title with cursor a few times and watch it pop back to normal
                Hi,
                Same problem here!
                Edius 4.54
                maybe it is pal related?
                Rob
                www.volkenkunde.nl
                Edius Broadcast 4.54| 3X SP hardware 1 NX | Dual Xeon 3.2 Supermicro | Carbon coder
                  I've the same problem here. PAL Australia.
                  Just exported 3x edits to mpeg2 and had to go back and re-export them as some of the 16:9 titles rendered out 4:3. Some switched halfway through their duration, these had fades up and down on them. They would start out 4:3 and switch after the fade up.
                  As Anton said, if I scrolled through the project first they would switch to 16:9 and then I could export safely. Had to be careful though, as areas of a timeline that had been pre-rendered because of realtime playback issues when editing (Max RT2 system) may still contain 'bad' renders containing the switching problem. These had to be deleted and dragged through before they would play/export correctly.
                  A real pain in the A...!
                  I know I could export from TMP as a TGA and avoid the problem, but that's an extra step.
                  I have noticed this on both my systems as listed in my signature.
                  When in a 16:9 project, my TMP 'video' window is also stretch horizontally. Is this the same for other users? Not a huge problem, just annoying.
                  Also, real Alpha support would make my year! I know this is not the right place for feature requests but I've just finished a very long stint with little sleep and these were the only two things that annoyed me with Edius over the time. Oh, dragging through a timeline with Boris effects in it could/would cause a crash.
                  Simon
                  System 1 - SP with Edius Broadcast 4.54 , 2x DUAL 2.66 Xeon CPU's, Tyan 2696, 2gig RAM, Sapphire 1950PRO 2
                  System 2 - RT2 MAX with Edius Pro 4.54, 2x Xeon 2.4ghz CPU's, 512meg RAM, Compaq
                    Simon
                    Oops. this was caused by my LCD monitor settings being wrong.
                    Simon
                      Simon,
                      Just curious - what OS are you running on System 2? 512MB RAM?
                        Hi TingSern,
                        XP - SD work only, no HD.
                        Simon
