audio pops between sequences
  • audio pops between sequences
    My workflow consists of creating sequences and then combiing into one master sequence. In my latest project there is an audio pop between several of the sequences. The pops are not in the original sequence. The sound is just a slight "click".
    How do I get rid of this noise?
    thanks
    Have you tried to open the waveform, located the tl cursor over the peak, right click and selected V-mute? You can also add a V-mute button to the tl button bar and adjust V-mute duration in settings.
    DVC laptop: W870CU i7; 17.3" 1920x1080; 2x 1TB 7200rpm SATA notebook drives; Edius 8.5WG; Windows 7.
      thanks. I went back and checked the source file and didn't hear a pop but when in the final form I did. So I reduced the volume and it went away. funny I would hear it one place but not in the other.
      thanks
        was there any vst audio filters on your source clips such as soundsoap etc?
        if yes, then the pops or clicks maybe normal
          These pops and clicks are NOT normal, but they are there.
          GV should really look in to this BUG, as other apps do NOT suffer from this !
            I know they are not normal, what I meant to say is that they are happening with the current version of Edius and soundsoap and maybe other vst plugins
              @ Anton, this was not meant as a personal attack, I think we all know what you were saying (writing)
              @ all, even with high end VST plug-ins like TC electronics & TL Audio you have these problems.
              Not only with the low end plug in provided with Edius ...............
                A quick work around would be to use Audio fades at in & out if you use any VST on the time line.
                This works for audio embeded in the video track or as stand alone audio on the audio tracks, still, be aware of the 3 frames delay it gives you as a unwanted bonus ..................
                  I had the same noises when i applied a free vst limiting filter.
                  With another limiter it worked fine!!!
                    Quick test, short clip on time line, say 1 minute or so, divide it into several clips, just cut every 10 or 15 seconds, then on alternative clips put a audio vst, limiter, compressor etc. make sure there are NO fades.
                    Does it pop, click, how ever you want to name it ?, does it have 3 frame's or more sync problems towards the video clip ? i think it should be 2x Yes.
                      Even if you fade in & out, the 3 frames (or more) audio sync problem still remains.
