Preview monitor displays max. IRE=100
    Originally posted by JackV View Post
    Besides using the preview window, I mainly use an external 1920x1080 preview monitor. This monitor is configured as an extended display of Windows. As a graphics card I use the Intel UHD Graphics 630 hardware and software, referred to in Edius as Generic OHCI.
    If I want to adjust the settings of the OHCI Preview Device (System settings> Hardware> Preview Device) I get the message: "Device doesn't support the current format. Unable to update settings. "
    I have no idea what the differences between the device and the current format could be and I don't get any information about that.
    JackV
    A search on the forum would bring this up. If you don't have an external card, you will get this message. Basically it means you are using software out vs a hardware card. You can turn that message off if you like in System Settings.
    Main System: i7 6950X OC to 4.5GHz, ASUS RAMPAGE V EDITION 10, Corsair Dominator Platinum 64GB DDR4 2800, SAMSUNG 950 PRO M.2 512GB , GeForce GTX 1080ti SC Black, Corsair AX1200i PS, Phanteks Luxe Case, 16TB RAID (4)HGST Deskstar NAS 4TB, Corsair H115i CPU Cooler, AJA Kona 4, BMD Intensity Pro 4K, Win 10
      Hi Anton,
      Also known as Firewire or IEEE 1394, the OHCI interface is not a video card interface, as I previously thought, but is a standard used to exchange data with DV camcorders.
      I don't know a monitor with an IEEE 1394 interface and I suppose it's not the intention to use a DV camcorder as a preview device.
      Therefore, I don't understand why Generic OHCI is present in the Preview Device window, nor why this option is checked (I can't turn it off). Besides, my PC doesn't even have an OHCI controller installed.
      Does only a DeckLink Mini Monitor (or a GV device) offer the possibility to display the full range luminance on a monitor or can this also be done via a separate video card?
      In your Preview Device window I only see the DeckLink Mini Monitor and not the RTX-2070 video card that is also present on your system. Maybe you have an explanation?
      I am very disappointed that Edius, a professional product, does not offer the ability to adjust the luminance range of the Preview window to produce full-range RGB videos and the user has to purchase special hardware, while it easily can be fixed by software.
      Applying special hardware is not an option for me; I also alternately use my external monitor as an extended Windows screen while editing.
      Therefore, I am unfortunately forced to use the following method:
      1. Compress the Y range from 16-255 to 16-235 of all clips to see the full dynamic luminance range of the original recording
      2. Edit the clips (for correct display on the preview window, in real time Edius temporarily expands 16-235 to 0-255)
      3. Expand the Y-range of all clips from 16-235 to 0-255
      4. Export the video
      5. A full 0-255 range RGB screen or TV now correctly displays the full luminance range of the video.
      JackV
        you need a GV or BM card in order to see the full range, in order to see the correct frame rate, in order to see correct component colors
        the graphics card output will give you a limited range, will cause picture tearing during pans because the refresh rate of a graphics card does usually not match the video, colors are wrong because PC mon are RGB
        EDIUS 9 WG with BM Mini Monitor 4k and BM Mini Recorder, Gigabyte X299 UD4 Pro, Intel Core i9 9960X 16 Core, 32 Threads @ 4.3Ghz, Corsair Water Cooling, Gigabyte RTX-2070 Super 3X 8GB Video Card, Samsung 860 Pro 512GB SSD for System, 8TB Samsung Raid0 SSD for Video, 2 Pioneer BDR-209 Blu-ray/DVD burners, Hotswap Bay for 3.5" Sata and 2.5" SSD, Phanteks Enthoo Pro XL Tower, Corsair 32GB DDR4 Ram, Win10 Pro
