I just upgraded to Edius NX with expansion kit and loaded Edius 4.52. When I play the timeline it continuously stops with "Playback stopped" error message and I have no audio whith playback. I have reinstalled all the programs. After first installation, it worked for a couple of hours. Dunno if I accidentally changed a setting. Please help.
Playback stopped and no audio while scrubbing
Originally posted by barryschutte View PostI just upgraded to Edius NX with expansion kit and loaded Edius 4.52. When I play the timeline it continuously stops with "Playback stopped" error message and I have no audio whith playback. I have reinstalled all the programs. After first installation, it worked for a couple of hours. Dunno if I accidentally changed a setting. Please help.
What are you playing back when you have the video stopping and what are the project settings?
You may need to swap PCI-X slots of the baseboard, when I setup my system it did same thing until i moved the board to another slot.AMD Ryzen 9 5950X, AMD Radeon 6800XT, 64GB RAM, EDIUS X WG.
Thanks Mark. I have S-video output to monitor but the monitor does not see it and RCA output from the bay to same monitor with same result. The project is set to HDV 1440x1080, audio 48000hz and rendering format uncompressed (YUY2) AVI. Will look at swapping slots on Monday. I had the cards put in but I have the installation manual. I'm not very technical.
HDV 1440x1080 project only provides video and audio at the component out optional board, do you have this board?
S-Video and composite will be dead in any HD project, this is normalAnton Strauss
Originally posted by barryschutte View Postand rendering format is set to Mpeg(Hdv).Anton Strauss
here are the settings I would use if I had no Edius hardware
http://www.videoproductions.com.au/edius45/HDV-OHCI.gifAnton Strauss
