Buffering Problem Edius 7.53
  • Buffering Problem Edius 7.53
    When playing or editing timeline clips my system stops and loads very often. I see the buffer is reading 4/5 or 5/5. I changed my buffer setting from 1GB Playback Buffer Size to 2GB. My buffered frames setting is at 10 frames. I have unticked the video filter in multi-cam mode. Nothing seems to work.
    Any suggestions please?
    Keith
    East Coast Video
    Edius Pro7, Intel i7 4770 3.4ghz Processor, 32gb RAM, ASUS Z87-Pro Motherboard, 3x2TB SATA, 500GB SSD, ATIR9 270X 4GB card, Samsung 24" Monitors, ADVC110 capture, Windows 7 Pro x64
    Close your Audio mixer or set all of the settings to OFF.
      My audio mixer is not running to my knowledge unless I open it. Where would I locate the settings to confirm?
      Keith
      East Coast Video
        I was referring to it being displayed (opened) or not.
          What files are you editing. What drives are they on.
          Ron Evans
          ASUS PB328 monitor, BenQ BL2711U 4K preview monitor, EDIUS X, 9.5 WG, Vegas 18, Resolve Studio 16
            I am currently editing a multi-cam event that is on the PC main drive (the drive is only 10% full), however I was editing a photo montage that was on an external drive and had the same issues.
            Is the buffer supposed to be at 4/5 and 5/5? Seems very low.
            Keith
            East Coast Video
              When the audio mixer has a track, or track setting active you will see the 5/5 setting. Also, this setting will display during multicsm sessions.
                So if the 5/5 is normal, this is not causing my system to freeze every time it does an automatic save? Is it a RAM problem maybe?
                Keith
                East Coast Video
                  Exit multicam and play a file. Take a screen shot of the Edius timeline screen. Is the buffer full?
                  Playback performance when in multicam will be determined by the performance of your system and subsystems. The buffer readout will always be based on 5/5. A slower system may read 3/5 or lower.
                  As I said, this is also the case with the mixer being active and not just visible.
                  When in multicam mode, do you already have effects applied? If so, disable then within multicam.
                    this is normal.. I still use 7.53.. your editing many clips at once and if they are HD or above you will have issues playing it back in real time.
                    if this issue has just happened than I suggest checking your power options in the control panel. should be set to high performance.
