Assuming someone works with a four audio channel setting (DV, 32kHz, 4ch): is there a way to output those four audio channels seperately? I know one D/A converter which can handle this (AJA LA-Io) but it's Mac only. Any ideas? TIA!
Outputting four audio channels seperately
Edius SD and HD solutions can output up to 8 channels separately...I'm not sure if you can find a cheaper solution on the grass valley/canopus side...Aristotelis Bafaloukos
BEng (Hons), MSc, MBCS
Ctrl+Alt+Delete
Edius SP SDI is now dirt cheap, under USD3KAnton Strauss
what about professional DV deck?
http://www.sony.com.au/objects/pdf/p...1600_1800P.pdf
4 x XLR in and 4 x XLR out and firewireAnton Strauss
ADVC 3000 will do the Job as well
http://www.canopus.com/products/ADVC...ndex.php#specs
Digital Audio Input
SDI- Embedded audio (SMPTE 272M-A)
- 2 x BNC (channel 1/2, channel 3/4)
- 32kHz, 44.1kHz, 48kHz, 16-bit, 20-bit, 24-bit
(unlocked/locked, converted to 48kHz locked)
- 32kHz, 44.1kHz, 48KHz, 16bit, 2-channel (unlocked/locked)
- 32kHz, 12-bit, 4-channel (unlocked/locked)
- 4 x 3-pin XLR (channel 1 to channel 4)
Ctrl+Alt+Delete
I can confirm that the ADVC-3000 will accept a 4 audio channel DV signal and output 4 channels of analog audio via the XLR out ports. It is the only ADVC product that will perform that function. List price: $4499 USD
The only other way to get that workflow with a GV product is to buy an EDIUS HD turnkey and use the Multi-input/output box (we call it the "MIP") for that job. Needless to say, that way is a bit more expensive....
Originally posted by STORMDAVE View PostI believe EdiusHD is only sold as a Turnkey through Grass Valley/Canopus.
You can also buy it from some of our authorized dealers and system integrators, though the price is the same. For now.
