Lose audio when moving clip
  • Lose audio when moving clip
    When i place a audio/video clip on the timeline and then move that to another video track, it deletes my audio...is there a setting to prevent such or how can I get audio back?
    thanks
    Strange. Can you do a screencaptureans share it so we can see how this happening?
      thanks
      Did you move the clip from a VA track to a V track ?
      Ron Evans
      ASUS PB328 monitor, BenQ BL2711U 4K preview monitor, EDIUS X, 9.5 WG, Vegas 18, Resolve Studio 16
        I have had this happen regularly, when moving the clip I have to watch it, when audio and video are shown on the outline then "release" the clip. If only video appears (blank centre) then only the video will appear on the VA time line.
        i7 3930K, Win 10 pro 64 Bit.
        RAM 32 GB.
        ASUS P9X79-Deluxe.
        PS Thermaltake 1kW.
        Graphics Gigabyte GTX1660 OC.
          YES!...thats what it does. Make me scared to move anything. I have had important audio disappear and not realize it til way later.
            I will get one made...i can reproduce it easily.
              I am a fan of using VA tracks but you have seen a downside if you are not careful in watching the clip outlines before releasing the mouse button. If placing from the bin it is more likely to get this issue and the possibility of getting audio in the audio track and video alone in the VA track. From the bin you can of course select track and add clip to timeline to avoid errors.
              Since all my projects are multicam once set up in sync I move nothing of course, so only tracks I play with after the setup are V tracks ( for titles and graphics ) and A tracks. If you move clips a lot between tracks you may well want to change your workflow to only using V tracks and associated A tracks. I personally like to use VA tracks to see audio close to video, but never use the audio from them directly.
              Ron Evans
                As we all know I am not a fan of VA tracks and would prefer to get rid of them. Instead I would like the ability to "move" tracks as desired. That way you could designate tracks to be displayed much like the VA tracks but the function would always be like separate V and A tracks.
                  Well EDIUS could just work properly to a move of a clip with audio correctly into a VA track wherever the mouse points. In this case the problem is EDIUS not the user. Moving a clip with audio into a V track is user error. That is why in my mind I separate use of tracks. For me if its video it is in a VA track even without audio. Graphics and titles V tracks, audio A tracks. Automatically creating audio tracks with the VA audio would be good since I always mute and minimize the audio in the VA tracks anyway. But they are there if I screw up and need to get that audio in sync again or even check if the audio I am using is in sync with source. Manual syncing of tracks for multicam is much easier using VA tracks. For me the real value of VA tracks.
                  Ron Evans
                    I have this same with V and A tracks separately.
                    Pawel Chyrowski
                    Edius 9 Workgroup
