Source Browser not working for DVDs
  • Source Browser not working for DVDs
    I am running EDIUS 9.52 and using Source Browser to load in DVDs via an internal Pioneer BDR-209M. The DVD appears to load correctly (i.e. the total time is correct); however when I place the clip into the Timeline, the video and audio go blank (i.e. there is no content) after about 30 seconds. This is consistent for every load I have tried. Occasionally, the load is only a partial load (i.e. the total time is less than the actual). On three occasions, EDIUS has gotten a "not responding" condition and created an event log - but EDIUS kept working.
    I have swapped out DVD drives to an ITAPI iHAS324-98, but have the same problem. I can use another PC with EDIUS 6.5 installed and an ITAPI drive, and all the DVDs load via Source Browser with no issues.
    My point is that I am pretty sure I have eliminated the hardware issues, so the problem must be elsewhere.
    Any ideas?
    Tim
    EDIUS 9.52.6153
    VisTitle 2.8.0.5
    OS: Windows 10 (Build 1909)
    Processor: Intel i9-9900K 3.6 GHz (10.0.18362.387)
    Motherboard: Gigabyte Z390 Designware
    Cooling: Corsair H100i RGB PRO XT
    RAM: G.SKILL Ripjaws V Series 64GB
    Graphics: Intel UHD 630 (26.20.100.7262)
    Capture: Blackmagicdesign Intensity Pro 4K (10.11.5.0)
    CDR: Pioneer Internal Blu-ray Burner BDR-2209
    Storage: Samsung SSD 970 PRO 512GB, Samsung 970 EVO SSD 1TB, 2 Swappable Samsung SSD 860 EVO 2.5TB
    Have you tried just copying the files from the DVD to a hard drive and input from there ?
    Ron Evans
      see if the following option is ticked
      personally, I use PGC Demux (free) to rip a DVD to elementary streams and then load direct into EDIUS
      It can demux a full single layer DVD in 10 seconds and you are ready for editing
        Case Closed
        What I discovered (through some of Anton's old postings) was that post-v6 EDIUS versions do not re-construct the audio and video streams of a DVD that was created using a standalone DVD writer. See the two attached screen captures from v6.54 and v9.52 - the "Reconstruct Files" option in the "DVD Video Settings" section is not available in v9.52. I am not sure the reason the feature was removed, but I suspect lawyers and money were involved.
        Nonetheless, the best solution was to use a third-party software to load the audio and videos streams separately (not using Source Browser) and stitch them back together in the Timeline. I really appreciate the responses and advice.
        Tim
        EDIUS 9.52.6153
        VisTitle 2.8.0.5
          Is the latest version 1.2.0.5? Care to show a screen shot of your settings? Seems very simple.
          Thanks,
          Ara
            yes, that is the latest
            always copy the VIDEO_TS from DVD to hard disk first, then demux takes seconds
            see attached on how to use
              Screen Shots
              In addition to Anton's reply, here are some screen shots of how I use it.
              Tim
              EDIUS 9.52.6153
              VisTitle 2.8.0.5
                Thanks to Anton and Tim.
                Thanks,
                Ara
                  Anton. Are the vobs stitched together for each ifo? Also I noticed the audio file was about 5 frames shorter after I created the elementary stream. Is this what you experience?
                  Thanks,
                  Ara
                    all vob files within a title set are stitched together automatically
                    some DVDs have more than one title set, so you need to repeat this for additional titles
                    ac3 files can sometimes miss a few frames at the end, that is normal, it won't cause lip sync issues
                      Are you saying the .IFO is a title set?
                      Thanks,
                      Ara
                        yes, and if there is more than one title, you will see several of these
                        the first IFO is usually the menu and you don't need this, start with the next one
                          Out of interest Anton, what are you using just to rip a DVD to a single stream ie rename to mpg to put on to a USB stick. I currently reboot an XP drive with 4.6. I think that was the last version that disc capture worked properly.
                            if I want to rip a DVD to single mpg file, I use the Tmpg MW source wizard
                            the last version where DVD capture worked 100% was 5.51
