GV Licence manager issue
  • GV Licence manager issue
    Hi All,
    Since some weeks, months my GV Licence manager application is going crazy. After starting my computer and loading Windows 10 the GV Licence Manager is starting (its normal), BUT it creates a tonns of GV Licence manager icons on the Taskbar (see attachment pictures). Minutes long it just creating new and new icons, and after some minutes all are going down. GV Licence manager seems to be working, Edius is starting fine.
    But its so annoying, and from time to time it seems to be longer and longer till GV Licence manager is finishing this "job". Do anyone know a sollution to this?
    Edius 8.5 EDU; i7-7700k; GIGABYTE GA-Z270-GAMING K3; 16GB 2400MHz RAM; ASUS STRIX-GTX1050TI-4G-GAMING; Samsung 250GB SSD; WDC 300GB Raptor 10k RPM HDD; Samsung 1TB HDD; WD 500GB HDD; 3 monitor system (Hanns-G); 800VA UPS; etc.etc
    Originally posted by mcll
    Hi All,
    First step I would suggest is to uninstall edius, mync, and the licence manager (don't deactivate), reboot, dump the temp files, disable your virus scanner (this includes windows defender), and re-install Edius. It is also advise to add "program files\grass valley\edius9\*", "program data\grass valley\*", "users\username\appdata\roaming\grass valley\*" and tour video media drive to your virus scanner exception list.
    If you want to do a completely clean install, here are the steps as posted by Anton many times, which basically add the steps of deleting the contents of some of those exception folders I noted.
    1. uninstall EDIUS (do not deactivate)
    2. uninstall Mync (do not deactivate)
    3. uninstall GV License manager
    4. delete everything in program files/grass valley/edius9 except the plugin folder
    5. delete everything inside program data/grass valley
    6. delete everything in users/username/appdata/roaming/grass valley
    7. empty users/username/appdata/local/temp
    8. reboot PC
    9. disable virus scnanners and install Edius
