Hello all, thank you very much for your suggestions and tips. After some extensive testing the only way to get an image on my TV is by putting the project settings in Edius on 1920i50. Apparently my TV can not cope with progressive input. It is an older Panasonic HD plasma panel TV : TH-46P-Z85E.
WIthin the system settings from Edius I can select the format pull down option in the settings for the IPRO4K but when I than change the project settings to anything else than interlaced, Edius crashes (9.52).
@Anton : I do not have the options in the menu of the IPRO4K to downconvert the preview output. Those are the only options i get in the menu : see attached file.
MY workaround : editing with project settings on 1920i50 and change settings before exporting. I guess I will not loose any detail if i do it like that ?
I still wonder why the BM Media express app is able to show a perfect picture on the TV screen from my gopro (directly linked input and output on the IPRO4K card) ?
