Mpg video not importing
  • Mpg video not importing
    Hi
    Can anyone kindly explain why I cannot input mpg video. It plays in Windows 10 but Edius 8 refuses to accept it - as does mync.
    Attached media tab text.
    Thank you
    Roger D
    As per your attached txt file, this may have something to do with your problem:
    Scan type : Progressive
    Scan order : TFF
    Scan order : Top Field First
    Interlacement : PPF
    Interlacement : Progressive
    Is the video progressive or TFF interlaced? It can't be both as suggested by this section in your posted txt file.
    I have imported mpeg2 files before without problems, but have none handy now to check with media info for comparison.
      Looks like the container is m4v (apple ?)
      Just as a test can you rename the m4v to mp4 and try....
      Tony D.
        if the container is apple, be sure QT 7.7.9 is installed and activated in EDIUS
          According to the txt file posted, the codec is mpeg-2, so should not be in an m4v or mp4 container. I actually don't see any info in there regarding the writing application/library or the container.
            Thank you all, sadly none worked. I have QuickTime ticked, renaming to mp4,, m4v etc does not work, but, as an mp4 I can load into Freejoin which does re-encode and opens in Eduis, completely out of sync though.
            Have attached a MediaTab export from different clip from the same source, hopefully might have more info & throw a little more light.
            Roger D
              Do you have a sample file you could post a link to? I'd be happy to have a look and try to figure out a solution for you.
                You are correct Bern, last night I read the txt too fast i think, well no harm done :)
                Maybe the file is a recording from a TV tuner or USB attached device that has it's own "funny" file format, similar to what DVD recorders do...
                Trying to concert the file would be most likely the best option, a sample of the file would be of great help to figure out how to go about...
                Tony D.
                  Given your forum join date of 2007, do you by chance have ProCoder?
                  Regards,
                  Jon
                    can you upload a short clip, the shortest you have
                    antonsvideo.wetransfer.com
                      It is from a USB recording device but what puzzles me is that it plays perfectly on various file players, but not Edius. Curious why as much as anything and willing always to learn.
                      Link for 30sec clip.
                      https://drive.google.com/file/d/1g5c...ew?usp=sharing
                      Roger D
                        Edius and other nle's expect audio and video files that follow certain industrie rules.
                        Usb devices, dvd recorders and often handphone and non professional portable devices have often a non conform codec, frame rate and funky audio in an not allowed container.
                        To make edius import the video you could convert to a file that is according to industry standard.
                        The are many free and paid software for that, you just need to find one that can read the original file.
                        Tony D.
                          I have removed the audio from your clip, 1 stereo track and 1 mono track and then the video import fine in Edius.
                          I think you need the convert the audio to something else than original, i did pass-through.
                          edit: I just converted the clip in handbrake to mp4 and used the stereo track (deleted the mono track) to AAC audio, it plays fine in Edius 9.52....
                          Tony D.
                            I can confirm that the native file will not import, but the problems appears to be with the container, not the codec.
                            I used xmedia recode to make a new mpg file, but set the set and video and audio options to copy (not convert) so all it is doing is making a new container and copying the audio and video streams into it. The resulting file imports fine.
                            Xmedia Recode is a free ffmpeg based batch encoder (similar to handbrake under the hood), but unlike handbrake, it can create more formats than handbrake
                              Tony & Bern.
                              I do use Handbrake a lot, but the mpg I had problems with locked at around 50% each time I tried it.
                              The files are sent from a friend to edit for him and whilst I could re-encode with other software I wanted to find the reason so it could be eliminated for any future files with the same problem, (I'm getting rather aged and do less editing nowadays, the only things I seem to edit these days is drone footage.)
                              Many thanks to all, keep your 2 metre distance & keep well.
                              Roger D
