How to fix moiré
  • How to fix moiré
    Has anybody a golden tip to fix or even avoid moiré.
    Or is it a camera issue ?
    Edius 9.5 / X ,Win 10 home
    Asrock Phantom gaming 6,
    CPU Intel I9-9900K
    500 Gb M.2 Samsung SSD 970 Pro plus
    1 TB M2 Samsung SSD 970Pro
    SSD OCZ 256MB
    WD 4TB HDD
    2 Dell monitors UP2716D
    First of all. Use OLP Filter on camera e.g. Rawlite, Mosaic. I use Rawlite on my BM Pocket (original) and Micro.
    In post you can use BeautyBox plugin.
    https://youtu.be/pIRO9-9awiE
    Sometimes using of chrominance helped. Same process like above.
    Pawel Chyrowski
    Edius 9 Workgroup
      Unfortunately I don't own a BM camera,and I don't find external filters who does the job.
      Software = no Premier pro.
      Bud thanks for the input.
      Edd
      CPU Intel I9-9900K
      SSD OCZ 256MB
      WD 4TB HDD
        I found a way with Mask to select the most affected areas and put some blur to it,and the result looks much better !
        THX.
        CPU Intel I9-9900K
        SSD OCZ 256MB
        WD 4TB HDD
          Moire patterns happen in the image when the item being shot contains regular patterns, such as Venetian blinds or clothing patterns, that are close to the spacing of the sensors (pixels) on the imaging device or "beat" with the spacing, especially raster line spacing. It is also called spatial aliasing. One solution is to avoid those types of objects in the scene if you can. That is way TV talking heads don't wear patterned shirts. Changing the zoom setting or camcorder position may help.
          You also can see it if you scan magazine images at certain resolutions. Scanner programs often have a "de screen" filter setting to minimize this.
          What camera was used to shoot the video?
            A Sony PXW-X70 with the 4K software.
            During a panorama,with lots of roof tops, the roof tiles gave (seen at home ! )
            an enormous moire.
            Avoiding that is i.m.o. inevitable.
            i'm gone try to solve that with some local ( mask ) blur effect .
            Thx.
            Edd
            CPU Intel I9-9900K
            SSD OCZ 256MB
            WD 4TB HDD
              are these 4k clips in a HD project? If so, make sure Lanczos3 HQ is enabled in EDIUS project settings to eliminate these issues
                You may also notice that in UHD they are not there , at HD they may not be there but when encoded for SD they appear depending on TV and any upscaling from a disc to the TV. This is why Lanczos 3 is important for all these cases.
                Ron Evans
                  4K clips in a 4k project,Lanczos 3 was set "smoother",I've set it now to sharper (best for progressive movie).
                  I don't have a HD setting,probably because it's the pro version I have.
                  Are there advantage in filming 4K and encoding in a HD project ?
                  CPU Intel I9-9900K
                  SSD OCZ 256MB
                  WD 4TB HDD
                    Originally posted by edver1 View Post
                    4K clips in a 4k project, Lanczos 3 was set "smoother",I've set it now to sharper (best for progressive movie).
                    I don't have a HD setting, probably because it's the pro version I have.
                    you can make any SD, HD, 4k or custom size preset in the Pro version
                    if you are viewing via a dedicated output card connected to a 4k TV, all should look well (don't use a 4k PC monitor)
                      Anton,Ron,Jerry and all you guy's
                      Thanks for Your'e input (once again).
                      The dedicated card and a decent monitor are on my list for Santa claus (here it's Sinterklaas),and I've been good so maybe ?
                      I will see this evening what the mask and blur effect do.
                      Thx
                      CPU Intel I9-9900K
                      SSD OCZ 256MB
                      WD 4TB HDD
                        Thx
                        Yess, they are all very helpfull and they deserve a lot of thanks.
                        From another Belgian... (Namur)
                        Main System: Azus Z87 Pro, [email protected], 16gb ram, Nvidia GeForce GT 630, Windows 7 Pro 64, Samsung 840 pro, Edius 8.53.2808 WG and 9.54.6706 + NXexpress or HDspark, 2T separate video SSD.
