Before I upgraded, I highlighted two clips, pressed Ctrl-P and the Video transition worked fine (i.e. I got a 1-second Dissolve between the two clips - Default Video transition). See attachment labeled Pre Update.PNG. Since the upgrade, I am getting a Fade-In on the Mix track only on the 2nd clip, but no transition on the Video track or Fade-Out on the 1st clip. See attachment labeled Post Update.PNG. Additionally, I can delete the final frame on the 1st clip, and the transition works properly. Anyone else seeing this same issue?
Video Clip Transition not Working with V 9.51.5532
Tim
EDIUS 9.52.6153
VisTitle 2.8.0.5
OS: Windows 10 (Build 1909)
Processor: Intel i9-9900K 3.6 GHz (10.0.18362.387)
Motherboard: Gigabyte Z390 Designware
Cooling: Corsair H100i RGB PRO XT
RAM: G.SKILL Ripjaws V Series 64GB
Graphics: Intel UHD 630 (26.20.100.7262)
Capture: Blackmagicdesign Intensity Pro 4K (10.11.5.0)
CDR: Pioneer Internal Blu-ray Burner BDR-2209
Storage: Samsung SSD 970 PRO 512GB, Samsung 970 EVO SSD 1TB, 2 Swappable Samsung SSD 860 EVO 2.5TBTags: None
In the 2nd file I see the two clips meet at the end frame of clip one and the beginning frame of clip two. You need to make room on the clips for the effect to take place. Trim back from end of clip one by 1/2 second and trim in to beginning of 2nd clip by 1/2 second and you'll have room for a 1 second dissolve.Documentaries and Art Projects
Hudson Valley, NY
i7 8700K @ 3.70 Ghz/16 gb RAM
windows 10
284 gb SSD boot drive
2 TB work disc
2TB storage disc
EDIUS 9.52.6031
or without trimming, you can go to application settings and disable the option as seen in attachedAttached FilesAnton Strauss
Originally posted by antonsvideo View Postor without trimming, you can go to application settings and disable the option as seen in attached
I have never unticked that as it can "screw up" other tracks further down the timeline. If you are only working on one track then it is not an issue but that is a big NEVER for me. I guess it is down to the type of projects you work on.
Problem solved.
The "extend clips" (among other settings) got changed in the upgrade. Appreciate all the help, folks.Tim
EDIUS 9.52.6153
VisTitle 2.8.0.5
yes, mine is always ticked because I never use untrimmed clips, I am from old school where the camera rolls for a few seconds before the desired action starts and keeps rolling for a few seconds after it endsAnton Strauss
Originally posted by antonsvideo View Postyes, mine is always ticked because I never use untrimmed clips, I am from old school where the camera rolls for a few seconds before the desired action starts and keeps rolling for a few seconds after it ends
I'm old school too in this regard.Edius WG 9.55.7761, various 3rd party plugins, VisTitle 2.9.5.6, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX680 4GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 8TB Internal RAID 0/stripe (2x4TB Seagate SATAIII HDD's, Win7 Software stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX680 and one on Intel HD4600).
