Thank You all for the advice.
Edius Suddenly Acting Bizarre -- Jerky Playback in Overlay and Audio Drift
Originally posted by antonsvideo View PostI would advice to get 2 Dell 27" 2560x1440 and they work fine at 100% scalingEdius 9.5 / X ,Win 10 home
Asrock Phantom gaming 6,
CPU Intel I9-9900K
500 Gb M.2 Samsung SSD 970 Pro plus
1 TB M2 Samsung SSD 970Pro
SSD OCZ 256MB
WD 4TB HDD
2 Dell monitors UP2716D
Originally posted by edver1 View PostEnd this week or next,I will receive the Dell UP2716D monitors,if the output isn't smooth enough,would the BM intensity pro 4K card a good choice ?
If you want to critically see what your video is actually looking like, it is advisable to use a video output card or box and a video monitor, so that the frame rate and refresh rate are in sync or evenly divisible, and in the same colour space. This holds true for every NLE on the market.
That said, the BM Intensity Pro 4K is an acceptable entry level card for HDMI output connections to a video monitor or TV, but if you need a different type connection, such as SDI, or if you plan on capturing analog video with the card, you would be better off looking at one of their Decklink cards. AJA also make some nice cards, but they tend to be more expensive, and originally you could not capture with them in Edius, but this may have changed.Last edited by BernH; 01-16-2020, 04:46 AM.Edius WG 9.55.9157, various 3rd party plugins, VisTitle 2.9.6.0, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX680 4GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 8TB Internal RAID 0/stripe (2x4TB Seagate SATAIII HDD's, Win7 Software stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX680 and one on Intel HD4600).
Recording isnt on my list,Ïll triyng to match the framerate as much as posible of the recorded files.
My plan is to set one monitor in the colour space same as the camera an the other like the screens I play them
All this as much as posible.
An Aja card is above my budget .
Thanks for the info.Edius 9.5 / X ,Win 10 home
CPU Intel I9-9900K
SSD OCZ 256MB
WD 4TB HDD
so connect a proper TV to a BM4k Mini Monitor card
there are also a few Grass Valley cards you may still be able to buy like:
STORM Pro with Bay
STORM 3G or STORM MOBILEAnton Strauss
Originally posted by edver1 View PostRecording isnt on my list,Ïll triyng to match the framerate as much as posible of the recorded files.
You may not be able to adjust a computer monitor to be evenly divisible by your framerate. For example, if your video is 50p, 50Hz is normally not a valid refresh, and you may not be able to pick 100Hz, 150Hz, 200Hz etc. Also as I said, computer monitors operate in RGB, while most video is in YUV. This is not something that is normally changeable on a computer monitor. Colours are often close, but not exact.Edius WG 9.55.9157, various 3rd party plugins, VisTitle 2.9.6.0, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX680 4GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 8TB Internal RAID 0/stripe (2x4TB Seagate SATAIII HDD's, Win7 Software stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX680 and one on Intel HD4600).
Originally posted by antonsvideo View Postthe Dell Monitors are for PC graphics and not for viewing video
My sony video monitor is fast enough to not notice any latency relative to audio, so the BM IP4K worked ok, but on a lot of consumer tv's, the display has a more noticeable delay processing the video relative to the audio if the audio is monitored before the tv. If I was using a TV, I'd really want a de-embedding amp with some delay compensation to adjust for the tv latency, but with the monitor I have, I can just feed audio from the I/O box through a level control to a set of powered near field audio monitors.
I am not advocating one way over the other, but these are points that you need to be aware of if you are trying to set up a proper monitoring environment.Edius WG 9.55.9157, various 3rd party plugins, VisTitle 2.9.6.0, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX680 4GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 8TB Internal RAID 0/stripe (2x4TB Seagate SATAIII HDD's, Win7 Software stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX680 and one on Intel HD4600).
Originally posted by BernH View PostI prefer the Intensity Pro 4K as an entry level option for the analog audio output. With the mini monitor, you need to listen to the TV, take audio out of the tv to speakers, or pass the hdmi through a de-embedder or de-embedding amp before hitting the tv.
set the default sound device to BM and you will also hear all PC sounds via the Home Amp
if using analog audio from BM IP4k, I would then use component out to TV to maintain lip sync, because HDMI usually has a 40ms delayAnton Strauss
I realize TV's and monitors have a different "goal" and the basic techniques are
not the same,but with a good calibration tool you should get a decent similar picture ( not professional use of course ) or not ?Edius 9.5 / X ,Win 10 home
CPU Intel I9-9900K
SSD OCZ 256MB
WD 4TB HDD
Originally posted by edver1 View PostI realize TV's and monitors have a different "goal" and the basic techniques are
TVs in your country are 50 hertz, same as here in Australia
also, PC mon work in RGB, not ideal for videoAnton Strauss
Originally posted by antonsvideo View Postthe Dell mon will run at 60 hertz and when playing Pal video which is ideal for 50 hertz, you will get jerky results and horizontal tear lines especially during camera pans
Originally posted by edver1 View PostI realize TV's and monitors have a different "goal" and the basic techniques are not the same,but with a good calibration tool you should get a decent similar picture ( not professional use of course ) or not ?
Calibration will get colours close, but not exact and will do nothing for the framerate/refresh issue.Edius WG 9.55.9157, various 3rd party plugins, VisTitle 2.9.6.0, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX680 4GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 8TB Internal RAID 0/stripe (2x4TB Seagate SATAIII HDD's, Win7 Software stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX680 and one on Intel HD4600).
