Problem with Xplode Pro using Print To DVD
  • Problem with Xplode Pro using Print To DVD
    When using Xplode Pro transitions (paper fly, for example) and the Print to DVD function, the image is pixelated during the transition on the DVD. I've tried everything imagineable to fix this with no luck. The transition plays great from the timeline and if I encode the timeline to MPEG using Procoder it's okay. The problem only occurs when using the Print to DVD function.
    Any ideas? I'd really like to use the Print to DVD function instead of encoding in Procoder then having to use another app to author.
