Have Been Running A Dvx With Edius 4 For Several Months. Started It Today And Only Got An Error "edius Exe Ecountered An Error And Had To Close" In Windows. I Reinstalled Edius To No Avail. Then Reinstalled Windows Xp Then Reinstalled Eduis But Still Got Same Error Message.is This The Board? Or The Program? As All Other Programs Work Ok Except Dv Capture Which I Assume Is Tied In With The Board Functions.
Edius 4 Will Not Start
I had a similar problem.
Turned out to be some codecs that Nero had installed. I uninstalled Nero and everything worked again.System 1 - Win7 64/Edius 5.51/Asus P8/8Gb RAM/RAID0/i7 2600K OC/nVidia Quadra 600
is your soundcard working? this is a must for Edius to start
also, the souncard needs to be set as the default audio device in control panel, sounds and audio devicesAnton Strauss
Originally posted by pjsssss View PostI would try the Edius uninstall and be sure you clean everything out of the registry. Then the reinstall one more time. It is important to get everything "clean" befroe the reinstall.TingSern
Guys,
Thanks for all your replys, and as "tingsern" says, I formated the hard drive and reinstalled Edius, so no Nero or registry problems.
However, as an update (and just in case any of you encounter similar problems) a reply from the Tech support team a couple of minutes ago suggested I take the DVX card out, then try it. As soon as the card was removed it started straight away. NOw waiting for reply from Tech support to let me know what I do next (new card or what?). Will let you know, but thanks to the forum for all help offered, its much appreciated.
What DVX card are you referring to then? Details please - thanks.TingSern
