shortcut
  • shortcut
    I can't use the shorcut "go to the beginning of the selected clip "
    It doesn't work
    Only me?
    Sachem
    PC PRINCIPAL: intensificateur 4k pro - edius X- maximus heroX wifi - processeur Intel I7 8700K; mémoire 16 Go SKILL - xpredator2 - corsair 650W HX
    hello sachem...... wellcome on "board"
    is this the exact name from the shortcut???
    what is the versionnumber from your EdiusPro???
    I will it give a try......
    friendly greetings from europe\austria\vienna ....old Hans
      I don't think this exists anymore in 4.54 - but if it does I'd be very happy.
      Paul
        ...........but if it does I'd be very happy.
        the good thing: it is named: > Move cursor to Inpoint of selected clip <
        the bad thing: it will not work for me..... :-((
        look at http://ediusforum.grassvalley.com/fo...5539#post25539
        friendly greetings from europe\austria\vienna .... old Hans ;-)
          Shortcuts
          It doesn't work
          Only me?
          Sachem
          Welcome to the Forum.
          Do you mean like "Page Up" to go to the beginning of the clip. Sometimes you have to hit it repeatedly. Make sure the clip is highlit and the timeline cursor is on top of the clip. You can also use "Alt arrow left or right"
          Hope this helps,
          Ted
            Hi Vienna,
            I confirm, it does not work.
            Hello Sachem,
            You do read in shortcut list : "Déplacez le curseur sur le point d'entrée du clip sélectionné" and assignation (for me) is = (equal).
            But , nothing, nada, rien !
            It's a dummy shortcut
            Perhaps fixed in a next version ...
            Marc
            System : W7 Ultimate - MB: Asus Z170 - I7 6700K - Ram 16 Go - SSD1 256 Go (OS/log) - SSD2 1To (rushes) - HDD 4To (save) - Nvidia Asus GTX970 - HDspark - Edius WG 9 - Vistitle 2.6 - Robuskey - Mercalli4 - Neat video - Ignite - Hitfilm4Pro - AV : Eset Nod32 - Others : Moniteur Sony 32-EX500 - Cam : Sony EX1-R - 2 x Sony PXW-X70 - 1 x Pana GH5
            Edius in France
              I use A and S a lot, (move to previous/next edit point, hmm, is this not the same thing?
              Claire
                is this not the same thing? ... imho ...no
                timelineduration: 30minutes
                on bottom ......VA1 only 2 long clips i.e. one 12:00:00 .. second 18:00:00
                on top.............VA2 from 12:00:01 to 30:00:00 are 60 short clips
                the cursor stands i.e. on 26:12:24
                how many "a" are necessary for go to the "INpoint" from second VA1 clip [12:00:01 ] ????
                please excuse my "gibberish" english ..... old men in old europe...... ;-)
                  Originally posted by Marc44 View Post
                  Hi Vienna,
                  Marc
                  It is (so far, in the latest beta build).
