Huawei P30 Pro video problem
  • Huawei P30 Pro video problem
    I have a problem with video, imported from Huawei P30 Pro, in any resolutions (3840 x 2160 29.*p, 1920 x 1080 60p) and in any codecs - h264, h265 . Video looks like has 2 different fields in motion scenes in timeline and the same in exported file. These no such a problem when I watch original imported videos in various players. Windows 10, Edius 9.50, QuckTime installed.
    You might mention which version of Edius you are using.
    Jim Willett
    UAB CIRC
    Edius 9.4
      What are your project settings? Does the framerate match your source footage?
      My System: Edius Workgroup 9.51 & 10.0, Intel I9-9900K 3.60GHz Liquid Cooling, MSI Z390-A PRO MB, 32-GB Mem, GeForce GTX 1660 6GB GPU, BM Intensity Pro 4K Card, Win 10 Pro
        there is no project setting frame rate suitable for phone footage because most phones record variable frame rates, such as 29 or 30.1 etc
        the best you can do is Alt+E on the phone clip and set optical flow
        and use a similar project setting frame rate such as NTSC 29.97fps progressive
          antonsvideo
          Thank you for respond. Turning on Optical flow option has made clip even more strange looking - shadows on some objects.
          In fact, I was able import one footage without artefacts on video. But I didn't notice what set of codecs was on my PC. But now, I can delete and import again that footage from only one folder. If I try import this clip to the same project from another location or if clip have been renamed - I get bad result again, just like Edius project "remembered" conditions in that particular clip was imported.
            can you provide a screenshot of your project settings with advanced expanded
            also, a screenshot of the imported clip properties, all tabs
              Ok. ASAP after I will back from vacation
