No Audio on MP4 Files
  • No Audio on MP4 Files
    Hi, I've got a problem that I haven't encountered before. I'm exporting files using MPEG-4 for audio that play back with no problem on my computer but now for some reason, they won't play audio within Edius. Tried MPEG-2 as well - no luck. Audio otherwise is working in Edius.
    Any help would be appreciated.
    Do you see the audio level meters moving when you play them?
      No I don't. But the same clips play fine in Premiere Pro.
        Can you provide a sample here? Do you have QuickTime installed?
          I don't have quicktime installed it seems - should I install?
            Yes. Go to Post #1
              I just installed QuickTime and followed instructions but still not working. I've attached a sample file to see if that helps to troubleshoot. Thanks.
                I can confirm that your file made with the TMPEG plugin does not play audio in EDIUS
                I think it is because the audio is AAC MAIN instead of AAC LC, check the TMPEG settings
                  Did you create the file in the TMPGE AVC plugin? I noticed the version being used is much older. The current version is 1.2.0.5. Update before going forward.
                  Here is a file created using 1.2.0.5. See if it plays in both Edius and Premiere.
                  Anything Goes from AVC PLUGIN.zip
                  The file was created using constant bitrate rather than variable bitrate and LC audio.
                  Here is a preset for the TMPGE plugin.
                  TMPGE preset for Anything Goes.zip
                  You can adjust the bitrate, but don't change any other settings. If it works, you can try a VBR setting.
                    Where did this file come from? We will pass it on to support and see what we can find.
                      TMPEG mp4 exporter plugin for EDIUS9 according to mediainfo
                      the audio is set to MAIN instead of LC
                      I am not sure if EDIUS is supposed to support MAIN ACC audio?
                        Anton is correct about the audio not being set to LC.
                        This is not a GV issue but a settings issue with a 3rd party plugin.
                          That seems to be it. I changed to encoding audio as AAC LC and that worked! It's strange because I don't recall having problems before --maybe I changed the audio output from TMPEG and didn't realize it.
                          Anyway, thanks!
                            It's from TMPGE and audio was set as AAC Main. Looks like that's not readable in Edius?
                              Did you update yet?
