Keyframes with Color Correction
  • Keyframes with Color Correction
    Hi,
    Is there any way to keyframe a clip with Primary Color Correction effect?
    For example start with monotone for the first 5 seconds and then return to color.
    Thank you in advance
    Konstantinos
    You can use the blend tool
      PCC doesn't have any keyframing. You can do it very easily with the Color Balance filter.
        ...or better still duplicate the clip on a timeline above, add monotone filter and cross fade. It's worked for 15years...
          Much like Dave's suggestion, Honestly I would just put a cut point in the clip, make the first part monochrome, then dissolve with whatever duration you like.
            Using PCC in the blend filter, if that is what you meant, will not let it go completely monochrome.
            However, using it directly onto a clip allows full monotone
              thank you guys very much,
              Steve, I am not used with the blend tool, but I'll give it a try and I think it'll work fine.
              Jerry, I try the color balance filter and seems to work very good for me.
              DigitalDave and GrassValley_PS your way also seems to work perfect.
              What I did before posting here, was using CPP directly to my clip, and cutting the clip to smaller clips, then adjusting each clip separatly till I get the result I wanted. But this is far a difficult way and of course now my last option.
              Konstantinos
                Not quite. You use RGB tool. With modyfing the curve you add saturation as well. It's nothing to do with Blend Filter.
                Cheers :)
                Pawel Chyrowski
                Edius 9 Workgroup
                  I just tried this and it works for me Jerry although I have to make sure I turn on keyframing so I can drag the point to the bottom as it defaults to 50%.
