Workaround for AAF and DAW Samplitude found!
  • Workaround for AAF and DAW Samplitude found!
    Hi,
    I got this to work, and just want to share it.You need to have EDL Convert from CuiBono Soft to do this,though...
    Let me just outline the problem:
    Samplitude is a really cool audioplatrorm for post etc., but it doesn´t support AAF which has frustrated many.
    What I´ve been doing is:
    1. Download Sony Vegas demo - it runs for 30 days..
    2. Import your Edius AAF into Vegas
    3. Export your imported Vegasproject to a Vegas EDL (txt) file
    4. Import the txt into Edl Convert
    5. Save This as your Samplitude EDL
    And you´re up and running....
    I tried this multiple times now, and it works...
    Regards,
    Erik Hoirup
    Commercial Producer/Director
    HDSpark/Edius 6.03
    Adobe Production Package Premium CS5.5
    QuadCore 9660 4*3GHz(ASUS P5Q Deluxe), 16 Gb ram,nvidia GTX 285 1 Gb RAM- Laptop i7 GHz, 8 Gb ram - nvidia GTX440M 1,5 Gb ram :) All Intel-based
    Panasonic HPX500E P2HD, JVC HD-110E/JVC HD-200/JVC BR50 and lots of other fun stuff :)
    Does the same procedure work for EDL exported directly from EDIUS, or is too much data lost?
      I was looking in to the difference in EDL between EDIUS and samplitude.
      I have an app which supports vegas and samplitude edl and not AAF.
      When I try to open the EDIUS edl it tels me error in reading EDL and I get nada.
