Edius 9 and HDR
  • #46
    Just to let you know the latest 1.2.05 TMPEG AVC Edius plugin does have HLG as an option but it only has High 10 not Main 10 that I need as x265 is not an option
    The Separate version of Mastering Works 6 isn't specific and the TV does not autoswitch.
    TMPGEnc MW7 has H264 X265 Main 10 with BT2020, HLG BT2100 and the TV is happy to play the file sourced from XAVC out from Edius.
    The main issue I am seeing with HDR is noise sourced from SLOG3 to HLG.
    I also see a significant performance improvement going from GPU assisted Primary Color Corrector to no GPU assist.
    I will have to save up for an i9 system last time I looked there weren't enough PCIe slots on the MB.
    • #47
      Mike, thanks for letting me know that.
      When I create an HLG file from TMPGE using High 10 with a level of 5.1, it will not play on my LG. However, if I wash that same file thru Handbrake using my preset, it plays just fine on my LG.
      Try this file on your TV.
      https://drive.google.com/file/d/1wa2...ew?usp=sharing
      There are PQ settings in there as well.
      • #48
        Just to let you know Jerry
        Copy of correspondence
        Dear Mike,
        Thank you very much for your feedback.
        We will send this to the user's wish list.
        Best regards
        ---- ---- ---- ---- ---- ---- ---- ---- ---- ---- ---- ---- ---- ---- ---- ---- ---- --- --- TMPG Inc. / Pegasys Inc. Support Team URL; http://tmpgenc.pegasys-inc.com/
        http://www.tmpg-inc.com
        http://www.pegasys-inc.com
        > OK
        > Downloaded the trial MW7
        > Yes it will produce H264 HEVC (H265) Main10, HDR HLG, that the Samsung
        > QE55 QLED TV is happy to play and automatically recognises the clip as HLG.
        > The AVC Plugin for Edius 9 does not have X265 and therefore no Main10.
        > The TV will not play HDR HLG files with the High10 profile, so FEATURE
        > REQUEST I need X265 and Main 10 in the AVC plugin for Edius please.
        • #49
          Dear Mike,
          Best regards
          > OK
          I doubt that they will add an h.265 encoder to the Edius 9 plugin version. That would be a paid upgrade.
          If it is added, the most likely time would be with wht Edius 10 plugin, when that eventually happens.
          • #50
            I can only but ask Jerry
            • #51
              Mike, when using MW7, select NVENC for your output option and set it up normally for an HDR output. You will see that file render very quickly with the 1080ti
              This is my preferred way of exporting large files now.
              Those files play back on my LG, perfectly!
