Edius 9 and Quick Sync working without the iGPU terminated or attached to a monitor.
  • Edius 9 and Quick Sync working without the iGPU terminated or attached to a monitor.
    Hi.
    I'm just seeking clarification as I may have misunderstood something in the past. My understanding of Edius and Quick Sync was that the iGPU was supposed to be terminated, usually by connecting it to an active monitor. Is, or was, this the case?
    I have my i9 system working with E9WG and have all the H.264 and H.265 functionality working with the i9's Quick Sync co-processor but without anything attached to the iGPU.
    Have I misunderstood something, or is this how QS is supposed to work anyway, or is this a function of E9WG?
    In any event, it's super cool and reduces the risk of Windows getting confused with a multi-monitor setup and helps with the layout of surround configurations for monitoring the GUI via dedicated GPU software.
    Cheers,
    Dave.
    Originally posted by Liverpool TV View Post
    Hi.
    Cheers,
    Dave.
    1) "My understanding of Edius and Quick Sync was that the iGPU was supposed to be terminated, usually by connecting it to an active monitor. Is, or was, this the case?"
    Yes, that was so necessary.
    2) Since it works now for me (with 9.4) without termination (no monitor connection), I inquired (MMM in Munich and Filmpraxis in Nuernberg): This restriction is allegedly no longer necessary.
    Regards kurt
    Intel core i7-6700K / ASUS Z170A / 32 GB RAM / Intel HD Graphics 530 / SSD Systemdrive / Gigabyte GeForce GT 1070 / Win-10/64 Pro / EdiusX-WG (10.30)/ Mercalli (V2, V4 and V5 Plugin/64bit) / Resolve-17.4.30010 Studio / ImgBurn / PowerDVD etc.
    // Read > Test > Understand
      Regards kurt
      Hi Kurt.
      Thanks for that confirmation, I must have missed that information when reading up on 9.4.
      Cheers,
      Dave.
        My experience of using QS is not the same
        My Specs are listed below
        The Driver is 24.12.14.3086
        For me this was the first of the New Intel style drivers that worked
        I tested a 2 minute HD 1920x1080 25p clip, the timings were:-
        1 With connection to another monitor it took 20 seconds.
        2 HDMI cable was detached from the other monitor an QS Harware Encoder option to unchecked did not appear in export it took 30 seconds
          Hi John.
          Have you tried exporting H.265 without a monitor attached? I only ask as this is meant to be a thing with the latest E9. For me, QSV H.264 exporting was a big surprise as I was expecting to connect a monitor but I then realised that my playback had been taking advantage of it anyway.
          In my case I just let Windows update the driver to whatever it thinks is the latest and not anything specific from the board manufacturer.
          I don't have to order anything specifically in the BIOS between my iGPU and discrete one either, as long as the iGPU is in there for multi.
          Also, my build is the cheapest of its type, aside from the storage, so nothing special about the motherboard.
          Cheers,
          Dave.
            You are using 9.4 Workgroup or Pro ?
              Is this change based on Edius 9.4 or hardware specific? More specifically, the 9th gen CPU's and motherboards.
                No it wont
                  I never used to let windows change the driver as the i9 originally had problems so i used those drivers that was noted to work on the forum and starting off by re installing the driver on the disk and then updating manually
                  The latest major Win 10 kindly installed the new driver that worked
                    No it wont
                    That's odd?
                      Here is a shot of it exporting with cable connected
                        Although E9 is capable of QSV without iGPU termination, maybe this is also MB dependent? As I'm experiencing and as Kurt has confirmed, the function does indeed seem to work.
                        BTW. Whatever is the latest version on the GV site, that's the one I'm using.
                          I've never been able to get quicksync to work without the second monitor attached. In the past, it has been manufacturer specific when it was reported to work without a monitor.
                            Dave What is your encode time for a 2 min HD TL
                              I'd have to test that, all the stuff I've been doing on E9 is 4K/60.
