Hi guys,
Just planning a shoot with my new Canon XF-400 camera, and beginning tests. So I thought before I even start I'd ask you professionals for some advice.
1. Which format (codec) does EDIUS handle better? And seeing that I have yet to upgrade from my older editor - which might play and edit easier?
2. File size being virtually the same - do any of you witness a picture quality differential between the 2 codecs?
3. Which codec needs more EDIUS color correction in order to deliver the best end product? I've seen that the XF-AVC naked picture lends itself to not only easier color correction, but yields a better result that CC onto Mp4 pictures.
4. And finally - does the XF-AVC yield a reduced color and contrast picture (a RAW pix) and therefore needs a LUT to bring in up to acceptability?
Thanks for your help - I appreciate knowing a little more about the XF-AVC codec results before I begin the tests. I am used to ProRes, etc.
Alan
Alan
