i record video unknowingly 60 fps slow motion in prores is there a way to change the clips to normal 29.97 fps so i can have audio and video synch the same length
normal clips
Originally posted by admasv View Posti record video unknowingly 60 fps slow motion in prores is there a way to change the clips to normal 29.97 fps so i can have audio and video synch the same length
Any audio associated with this clip will not be usable as an alternate source, as it's speed will change with the video, but you could strip it off to a separate wav file before doing the speed change.
All of this is just general information. Without seeing the actual clip I am only speculating based on what you have written.Last edited by BernH; 06-17-2019, 03:50 AM.Edius WG 9.55.9157, various 3rd party plugins, VisTitle 2.9.6.0, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX680 4GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 8TB Internal RAID 0/stripe (2x4TB Seagate SATAIII HDD's, Win7 Software stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX680 and one on Intel HD4600).
On my video camera, once you record in slow-mo, there is NO audio being recorded with the video. I am wondering what video camera you are using?TingSern
Originally posted by tingsern View PostOn my video camera, once you record in slow-mo, there is NO audio being recorded with the video. I am wondering what video camera you are using?Edius WG 9.55.9157, various 3rd party plugins, VisTitle 2.9.6.0, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX680 4GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 8TB Internal RAID 0/stripe (2x4TB Seagate SATAIII HDD's, Win7 Software stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX680 and one on Intel HD4600).
My is camera is new bmpc 4k by pressing wrong button I end up HFR 60/29.97 slow motion is there way to go normal clips wıth audio1-ASUS TUF Z490 PLUS. I9 10850K CPU 3.6GHZ 3600. 10 CORES 20 LOGICAL PROCESSORS, GTX 1660 TI,64GB,STORM MOBILE,EDIUS X & EDIUS 9,DAVINCI.
Originally posted by admasv View PostMy is camera is new bmpc 4k by pressing wrong button I end up HFR 60/29.97 slow motion is there way to go normal clips wıth audio
Any chance you could post a sample clip?Edius WG 9.55.9157, various 3rd party plugins, VisTitle 2.9.6.0, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX680 4GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 8TB Internal RAID 0/stripe (2x4TB Seagate SATAIII HDD's, Win7 Software stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX680 and one on Intel HD4600).
I did a test on my BMPCC 4K (PAL standard). I recorded a very short footage with audio at 50 frames per second.
I opened that file in 2 different project settings - one at 50 frames/sec and the other at 25 frames/sec.
I would expect the project that says 25 frames/sec be seen in slow-mo.
BUT - no - EDIUS plays both projects from the same MOV file - in the same way - very normal - and the audio in both cases are also perfect.
I must be missing something somewhere?TingSern
Originally posted by tingsern View PostI did a test on my BMPCC 4K (PAL standard). I recorded a very short footage with audio at 50 frames per second.
I must be missing something somewhere?Edius WG 9.55.9157, various 3rd party plugins, VisTitle 2.9.6.0, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX680 4GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 8TB Internal RAID 0/stripe (2x4TB Seagate SATAIII HDD's, Win7 Software stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX680 and one on Intel HD4600).
hi tingsern
thanks for your test my question is when you press HFR button and record the clips are slow motion audio is short those clips plays perfect in edius as slow motion what i want is to play them is regular speed no slow motion1-ASUS TUF Z490 PLUS. I9 10850K CPU 3.6GHZ 3600. 10 CORES 20 LOGICAL PROCESSORS, GTX 1660 TI,64GB,STORM MOBILE,EDIUS X & EDIUS 9,DAVINCI.
I tried pressing the HFR button and record at 50 frames / sec. The shutter shows 50/50 on the camera. I played back the clip on EDIUS at both 25 frames and 50 frames project setting - I don't see any difference in EDIUS playback.
You need to tell us what is your camera setting and your EDIUS project setting - at the very least.TingSern
