Primary Color Correction in Edius 9 bug.
    Interesting. I need to check (after my vacation) I don't use PCC much I prefer YCbCr tools.
    Pawel Chyrowski
    Edius 9 Workgroup
      'morning Grass Valley!
      Already some insight in the PCC anomaly? If it is a bug, will it be dealt with in 9.5?
      Nicola
      defacto.media
      www.defacto.media
      __________________
      Win10 SSD || Intel(R) Core(TM) i7-6820HQ || Intel(R) HD Graphics 530 / NVIDIA Quadro M2000M || 64 GB RAM || Edius 10 WG
        ....if I reduce blue, it will alter the remaining values
        or maybe it is the other way and 9 has a bug
        Anton, this would be not really an issue. But the problem is, when you change the value and slide it back to the original position, you will notice that every slider is on a different position than it had before.
        I therefore conclude that the algorithm that handles the relation of each slider to each other has a bug.
        Nicola
        defacto.media
        www.defacto.media
        __________________
          I tend to agree with you that it is either an undocumented feature or a bug
            Hi Anton:
            1) I now understand what nictau meant and can confirm this strange behaviour:
            2) If you set one slider, e.g. red, to a certain new value (precisely via numeric input) and then return to the previous value of red, the previous values for green and blue are no longer correct.
            3) I therefore agree with your opinion.
            BTW: I especially like the phrase "undocumented feature".
            // Sounds much more friendly than "bug" :-)
            Gruss kurt
            NLE: EDIUS-X(10.34.11471)-WG​​​; RESOLVE-18.6.00006 Studio
            // Read > Test > Understand
            • #21
              I am wondering how you experts tell the precise colour from EDIUS interface? I certainly cannot. That's why I prefer to generate a precise LUT from outside EDIUS first - then load that into PCC.
              • #22
                Hi:
                1) I am not an expert in the sense that you might mean it.
                2) I have used the words "precisely" and "numeric" only to describe how to test the problem by oneself.
                // But I will try to improve my English further (its not my native language).
                Regards kurt
                • #23
                  Guys, this is completly normal nad logic. If you move eg. RED you always adding or removing the Luma (Y). In RGB you alwyas have connected Chroma (RGB) values with Luma (Y). That's why you alwyes adding Saturation when you modifing the Luma. If you want to separate this thing use 3-wheel or YUV Curve (YCbCr tools).
                  Of course you can do this in Davinci (separate Y and RGB), but this tool is mostly use RGB not YUV ( YCbCr native video color model).
                  Pawel Chyrowski
                  Edius 9 Workgroup
                  • #24
                    Hi All who are interested:
                    We got a feedback from Japan (in summary):
                    The reported error with the sliders in the primary color correction is being worked on.
                    Probably with 9.5 comes the change.
                    Regards kurt
                    • #25
                      Regards kurt
                      Thanks Kurt.
                      Nicola
                      defacto.media
                      www.defacto.media
                      __________________
                      • #26
                        Thanks Kurt.
                        I had asked Mr. Lehmann-Horn (from MMM in Munich) to try to clarify your question - bug or no bug.
                        So the thanks are due to him and his team.
                        // I pressed only the button to start the rocket ;-)
                        Regards kurt
                        • #27
                          Hi nictau:
                          I have tested Version-4.0(5106):
                          The above problem seems solved!
                          // I think your (our ;-) ) problem has disappeared with the new build.?
                          Regards kurt
                          • #28
                            Hi nictau:
                            Regards kurt
                            Yes, it has in deed. For me the most important fix in the new update.
                            Greetings.
                            Nicola
                            Nicola
                            defacto.media
                            www.defacto.media
                            __________________
