Edius 8 Pro constantly crashing (new problem)
  • #31
    I sent you information for an Edius integrator/trainer. Did you ever contact him?
    He may becoming to the Atlanta area in the near future.
    • #32
      Originally posted by tryingtolearn View Post
      Hey Anton sorry for the delay been in New York shooting a week long Indian wedding and just got back
      I don't understand what you're saying to me
      I uploaded the entire crash report zip to that dropbox file
      I did the uninstall and reinstall with my anti-virus uninstalled and it's still crashing
      I really need to resolve this as I'm picking up editing from other videographers
      is there a way Edius staff could help me at all?
      I definately don't want to upgrade to 9 if i cant get the crashing with 8 to stop
      one of the comments was about talking to staff about integration or something?
      can you make a desktop shortcut to Temp folder, then open it and you will find the EDIUSCrash.dmp file
      can I see a screenshot of the content of the Temp folder? when is the last time you emptied it? I do this daily
      to create shortcut, right click desktop, click New Shortcut and type %Temp% and click ok
      now you will see a yellow folder on desktop called Temp, this is where EDIUS puts the Crash dump files
      • #33
        where did you send it? I didn't see it, I will check my messages now
        www.skysimonephotography.com
        www.skysimonefilm.com
        www.facebook.com/skysimonephoto
        Laptop:
        ASUS - 17.3" Gaming Laptop - Intel Core i7 - 16GB Memory - NVIDIA GeForce GTX 1050 - 1TB Hard Drive + 256GB SSD - Metal Star Gray
        Edius Pro 9 Windows 10
        • #34
          Hey Anton, when I search the TEMP folder for EDIUScrash.dmp it says "No items match your search'
          I don't have any folders in there named Edius of GV
          Laptop:
          • #35
            UPDATE before I had turned off the fast start in the windows settings, but I missed the step somebody else suggested about disabling fast start in the bios
            I disabled that then launched Edius and added monotone to an 8 minute video compiled of about 200 clips and it paused for 10 seconds but did not crash..
            hopefully that is the fix but I will keep you posted
            I should be doing a lot of video editing this week and next.. I would still like to figure out where my crash log files are...
            thank you everyone so far.. hopefully this is the solution but will keep you updated
            Laptop:
            • #36
              look for a folder inside Temp called Grass Valley CrashDump
              be sure you are in the correct Temp folder
              • #37
                He might have to list out his environment variables to see where the TEMP and TMP directories are assigned to. Use 'System Properties' and then the Environment Variables option. There are two sets of TEMP/TMP - one for the user under which he signs on to - and the other one under System variables. They might be different for him.
                • #38
                  I was so desperately hoping that we fixed the problem, but it just crashed just now while trying to edit color in a video.
                  I've attached a screenshot. I checked temp files last week and there was nothing from edius - no dump file - the crash report is the zip files i uploaded but its creating a new one now so i can upload that again, but the temp folder doesn't show anything from edius
                  Laptop:
                  • #39
                    Anton I followed the screenshot path you showed and it had one dump file from today so I have added it to this dropbox folder along with the crash report
                    I hope it gives some insight
                    thanks Anton https://www.dropbox.com/sh/hi4im10o9...ObMZ1IDta?dl=0
                    Laptop:
                    • #40
                      Been following this thread for a while now, and unfortunately I have no solution but was wondering, with so many possibilities tried and failed, would it not be possible that a bad ram maybe the culprit.
                      As the crashing is not sonstant with exact operation could it be a problematic video ram or system ram address?
                      So far this seems to be a pretty isolated case as I personally have no knowledge of anyone with Edius crashing.
                      Tony D.
                      • #41
                        you are running two antivirus programs, the default Windows Defender and AVAST, get rid of AVAST, uninstall it
                        you are also running Opera Browser, any reason for that?
                        can you do a scan of your PC with Malwarebytes free (but exit malwarebytes from taskbar when done, and do not set it to autostart with Windows)
                        • #42
                          Anton, just as an FYI, I run Avast (free version) with no problems, and I also run Opera with no problems. If a virus scanner installs correctly and Win10 doesn't misbehave, BitDefender should end up being disabled automatically, leaving only avast, avg, eset, etc. as the running scanner. Seeing BitDefender still running is not normal and potentially a problem.
                          Opera is just a chrome based browser that has a few nice features that chrome doesn't. I have been running it for close on 20 years (long before it became chrome based) with no issues.
                          • #43
                            lets wait for malwarebytes scan results, I think she is infected with something
                            I was only curious why anyone would use Opera instead of going to one?
                            • #44
                              Quite Possible. That's why I suggested a malware scan in post #2.
                              Oddball problems, if not fixed by a reboot/reset, are often indicative of failing hardware or malware/virus activity, unless the user has been "under the hood" tinkering with stuff they don't understand. Since this is a new laptop, hardware failure is probably not the issue.
                              • #45
                                For those of us that don't enjoy going to the opera, using it is the next best thing. ;)
                                (Not all of us can see the most famous opera house in the world when we look out the bedroom window to fuel the desire to go.)
