All of a sudden Edius keeps crashing.
  • #61
    Yes, that plays fine. Smooth as butter.
    Edius 8.53. Windows 10 Pro 64bit. Core i7 6700K CPU. 32Gb ram. Nividia GeForce GTX1060 graphics card. MoBo: ASUS Z170 A.
    • #62
      can you uninstall Quicktime and then tell me what happens if you add some of your mov files to a new project
      • #63
        No, that doesn't work. Takes a little longer after clicking on the file, but it still crashes Edius.
        • #64
          can I see the properties of such a file, all tabs
          • #65
            Hi Anton,
            I finally caved, & re-installed Windows. Just in the process of installing everything now.
            Thank you very much for all the time you have put into this. I really appreciate it!!
            • #66
              it is sometimes beneficial to do a clean installation of everything, I hope it will all work now
              • #67
                Same thing for me with mp4 and mov it crash...
                Éric
                Originally posted by Sportsaddict View Post
                Hi all,
                I'm hoping someone can help me out. I am using Edius 8.53 & until the other night it was very stable. Since then, i am having consistent crashes when trying to edit. It seems like it is only when i try to play particular clips. Seems like 4k .mov from a GH4 & .mp4 from a Canon XA 20 won't play. As soon as you try to, the program simply quits.
                I checked to make sure Edius was up to date & it is.
                I then updated Windows & that didn't fix anything.
                I re-installed Edius, & that too hasn't changed anything.
                Tried loading some other projects, & they too won't load, Edius simply crashes as soon as the program loads.
                Any help would be very much appreciated.
                Regards,
                Bryce
