Converting MPEG1 (MPG) to MP4 using EDIUS 9.31
    I think you should follow the original suggestion of exporting the audio to wav and muting the original audio and exporting. Do all of the files the same way at 48khz.
    By the way, where is the disable quicksynch setting?
    Jim Willett
    UAB CIRC
    Edius 9.4
      Quicksync is disabled by clearing the "use hardware" check box in the mp4 export settings page.
        After conducting numerous tests, I have come to the conclusion that VLC does not play nicely with the UAD Arrow audio interface. I have switched out of VLC to use MPC-HC .... and that one works nicely.
        Even playing original Blurays using VLC also leads to audio shuttering. The video is perfect - it is the audio.
        EDIUS 9 is fine - whether for video or audio. Also iZotope RX7 Advanced (for audio) is fine too. Only VLC has issues.
          I have been using Media Player Classic for a long time and never have any issues
          it even plays interlaced video perfectly without showing interlacing artifacts like VLC
            I'll second MPC.
            Every now and than I try VLC but still go back shortly after.
            MPC is simple, straightforward, fast and always works...
            Tony D.
            • #21
              I have kicked out VLC from my P72 laptop - now only using MPC to play the video.
              The only trouble is Handbrake - it needs VLC to preview the video .... so I need to keep VLC around - but I don't use it for anything else.
              • #22
                I
                No need to preview anything, you're P72 renders out the final file just ast fast :)
                Tony D.
                • #23
                  Got it - thank you.
