Problem with image import
  • Problem with image import
    I have a problem from several days. I don't know how it happened but now, when I try to insert a picture no matter which format it is, jpg, gif, psd... I received a massage : failed to open file.
    I use the BIN and when I open the dialog box, in object of type box only clips are active.
    When I select all files and try to insert image I get the massage again :( failed to open file...
    Please help me if you had experienced the same problem?
    What version of EDIUS are you using? Any virus or malwares on your PC?
      maybe you lost QuickTime player, that would cause this exact problem
        Yep, this was the problem. I reinstalled QuickTime player and..... everything seems to work OK.
        Thank you very much!
          no problem
