EDIUS 9.31 - Error in device preset
  • #61
    yes, you need Win7 at this stage, or wait a bit
    I have no idea why they had to break Matrox capture with 9.31 and later when it worked perfect in 9.30 and earlier
    it is like if a Win10 update would stop EDIUS from working
    Hey Anton,
    If you don't mind me asking, what is the hack you are talking about to get the MX02 capture working?
    I have the MX02 Mini Max, and it is showing up as a capture device, Although I have not actually tried a capture yet. Just wondering in case I have to try it.
    • #62
      the hack won't work unless you have Win7 and EDIUS7
      • #63
        I am still trying to get to the bottom of this because it seems unfair to disable a feature that works perfect with no public announcement
        there was no notes in the 9.31 update readme that from this moment, you will no longer be able to capture via Matrox
        • #64
          If I am not mistaken the Matrox is not officially supported under EDIUS 9.
          • #65
            Matrox is not even supported by Matrox :)
            but no matter what, there is no need for EDIUS declining the loading of clips captured via Matrox AV tools, we don't need EDIUS as a police inspector
            • #66
              Sorry but I thought it was about the actual capture not the files. :) My mistake
              • #67
                it was about both :)
                we will be happy if EDIUS 9.40 will load the files captured by Matrox AV tools, these files work in any player you can put a name to, but not in EDIUS 9.31 and 9.40
                • #68
                  Since it not supported capture won't be done. But the files should work that is a valid point. BUt since you can open them in other application is convert would work for now.
