EDIUS 9.31 - Error in device preset
EDIUS X WG with BM Mini Monitor 4k and BM Mini Recorder, Gigabyte X299 UD4 Pro, Intel Core i9 9960X 16 Core, 32 Threads @ 4.3Ghz, Corsair Water Cooling, Gigabyte RTX-2070 Super 3X 8GB Video Card, Samsung 860 Pro 512GB SSD for System, 8TB Samsung Raid0 SSD for Video, 2 Pioneer BDR-209 Blu-ray/DVD burners, Hotswap Bay for 3.5" Sata and 2.5" SSD, Phanteks Enthoo Pro XL Tower, Corsair 32GB DDR4 Ram, Win10 Pro -
I assume GV is aware of this as this was the first and only solution the distributor e-mailed me...
E-mail reply came very fast, so again, I assume that I'm not the only one who has faced this in the past as it seems a readily available solution that they are aware of.
Anyways, I'm happy that I'm up and running again, have a great weekend ahead :)Tony D.
wavearts / neatvideo / tmpgenc / hitfilm / imaginate / affinityComment
the real question is what program installed VCC 2017 and what program is now missing it?Anton Strauss
No real question, it was Edius WG 9...
I think the systems you build are too fast for you to see but in the first couple of seconds of the installation of Edius WG 9, the information window show the installation of the VVC 2017.Tony D.
Hmmmm......
Now I can't find the file in my installed history.
I was sure I saw the info screen, maybe too much red :)Tony D.
I just upgraded Edius to 9.40 and saw the installation of the file that previously gave me problems to install version 9.30
I started to doubt myself already but this is conformation that i haven't lost my marbles yet and that Edius itself does install MS Visual C++2017 Redistributable, this explains that GV support had a quick fix...Tony D.
is 9.40 working for you?Anton Strauss
I opened a couple of projects and saved them under a different name, just to be sure.
Time line plays fine, also did some cuts, no issues.
I haven't hooked up my Matrox yet so can't conform that its working.Tony D.
Does the MXO2 caputer in 9.40 ?Tony D.
I can also consider installing Edius 8 to capture, if that wouldn't break Edius 9
Preview out to TV is still working... right ?Tony D.
you can only get it to work with version 7 Matrox drivers and a little hack if you have Win7
Win10 does not work with version 7 Matrox drivers at allAnton Strauss
Hmmm.....
Can I force Matrox ver 7 drivers on Win 10 ?
Then for my case a second bootable SSD with Win 10 and Edius 8 and Matrox ver 7 drivers for temporarily use would be workable, Win 7 can't run on this laptop.
Hopefully the Matrox avi files are able to use in Edius soon.Tony D.
Ships, I just re-read that driver version 7 won't work on Win 10, Double ships....Tony D.
yes, you need Win7 at this stage, or wait a bit
I have no idea why they had to break Matrox capture with 9.31 and later when it worked perfect in 9.30 and earlier
it is like if a Win10 update would stop EDIUS from workingAnton Strauss
