Is anyone using Boris FX RED 4.2 plugin with Edius 4.54, are there any known issues? Any problems editing in SD, 720p or 1080i? If so is Boris working on these issues?
Boris works OK with SD but the field order is wrong when used as filter or transition with HDV in 4.54, Boris is referring all files from inside Edius as lower field first and HDV is upper field first, makes for a rather jittery playback.
I put a report into Boris and asked if an interim solution could be made for Edius HDV with a permanent selection of "Upper field" when comming from Edius for those who are using HDV but I may as well have sent to a black hole.
So be it I now use Mercalli and Vitascene both work exceptionally well with Edius, in fact in most cases there is no need to render like from Boris.
There seems to have been a disconnect between the two somewhere after 4.01
I have used Red 4.2 within Edius 4.54 and outputted as an uncompressed avi with no apparent problems. What sort of problems are people having? I did notice the wrong field order as mentioned.
Tom Koveleskie - Director/Producer/Editor Quarter Town Films - Independent Feature and Documentary Films.
Edius 8 WG with HDSpark, AMD 8 core FX 8370 Black Edition 4.3 GHZ, MSI 970A Krait Edition, 16 GB Patriot DDR3 1333 MHz RAM, EVGA Nvidia GTX 780 TI graphics, Win 10 X64.
No problem if Boris used as a stand alone, output using Canopus HQ works a dream with Transparent alpha, but if used as a filter or transition with HDV the filter or transition has jitter (incorrect field)
Barry
Finally got a reply from Boris they have recognized they have a problem and are looking into it.
It may become useful after all
"Not even light can escape from black holes"
Regards Barry
