We have multiple Edius suites working of a network. When loading the same source clip into the player in two edit suites, Suite2 is playing smooth vision (as recorded) and the other (Suite1) is playing the same clip with a strobe or incorrect field order appearance. All settings appear to be the same across both suites. The really confusing part is when footage is edited in the 'clean' Suite2 and opened in Suite1 the sequence plays the footage fine, however when you match frame the clip and load it into the player it applies the 'flicker fault' again. If you then edit the match framed clip from the player into the timeline, the flicker remains, thus having the same clip in the timeline playing with and without the flicker fault.
I feel the 'faulty' suite is applying some sort of setting to the clips when loading them into the player, thus is affecting the footage during edit and when conforming for broadcast.
Any help appreciated.
