Edius Stabilizer does not work properly with nested sequences:
  • Edius Stabilizer does not work properly with nested sequences:
    Hi:
    In the timeline I have a nested sequence > I drag the Edius-stabilizer onto this "clip".
    My test runs about 1 minute, so that I can observe the completed percentages nicely in the background job:
    After stabilization (background job has finished) > I save the project > quit Edius > restart Edius > stabilization starts again immediately (the background job shows the percentage of work done !!).
    This actually looks like a BUG (if I assume that a nested sequence should behave like a normal clip).
    // But this is not always done by nested sequences anyway: Waveform is not displayed, for example.
    Any ideas ??
    regards kurt
    NLE: EDIUS-X(10.34.11184)-WG​​​; RESOLVE-18.5.00025 Studio
    // Read > Test > Understand
    Hi Kurt
    Happy New Year. I dont think it will work correctly on a sequence containing multiple clips. I would not have considered doing it like that only clip by clip and then nest the sequence - others may disagree. As you say, a sequence is NOT a clip else we would have a waveform...first whinge of 2019!
    DD
      Fully agree with Dave. If stabilising is needed then I do it on a clip basis which can be fine tuned to suit each clips movement, and would not consider doing it on a nested sequence. Peter
      i9-7900X OC, Asus TUF X299 Mk2 MB, 32GB Mem, 250GB Samsung 960 Evo M,2 NVMe for OS, HDDs for work files, GTX1080Ti 11GB, Win10 Pro 1809, Edius 8.5 WG, Sony FS7 main camera
        Hi:
        The question arised (by a forum-user, german edius-forum) because stabilizing with Mercalli does not show this behaviour.
        // I for myself do not use any stabilizer on nested sequences.
        Regards kurt
          Just tried this with 3 diverse clips (sequence1) and dropped this into sequence 2. Added Mercalli. It seemed to work.
          Added an 18 minute sequence into sequence 2 and again added Mercalli and went for a walk. Edius produced an error report. Not surprised as this is no way to edit.
          Normally I would only stabilise individual clips. Don't forget you can add Mercalli to any number of clip and then Tools->mecalli & batch render the 'mercalli' clips over 'lunch'.
          Sys1: Gigabyte Z370 HD3 i7 8086K(4.3Ghz), 16Gb ram, 256Gb SSD system + 2x2Tb Graphics: nVidia 1060, (W10 Pro) BM IP4K, E8v3 WG; Vegas Pro19; Davinci Resolve18_Studio, GH2(hacked), Pana HC-X2000E, GoPro5
          Sys2 :Clevo i7 6700K 2.5Ghz,16Gb ram 2565Gb SSD + 1Tb, (W10 Pro), Software: E8v3 WG; Vegas Pro19,Davinci Resolve18_Studio
            Added an 18 minute sequence into sequence 2 and again added Mercalli and went for a walk. Edius produced an error report. Not surprised as this is no way to edit....
            Totally agree - kurt
