Work Group 8 to Edius 9
  • Work Group 8 to Edius 9
    I own the latest incarnation of Edius Work Group 8. I am confused about moving to 9. The reason I spent the bigger money on Work Group was so I could take advantage of the feature of being able to set the editing resolution to half or even lower while editing.... making 4K and 60P editing without stuttering or jamming (which is gold and a must have )
    My questions are: 1. Does Edius 9 have this feature? or do I have to go to workgroup 9? Upgrading to work group 9 from work group 8 is pricey. $379 US. I understand the Edius 9 has many new feature which allow a better flowing work flow. At this time I am only a little time editor at home and I don't need any global or satellite feature that the pros use. Does anyone have some advise for me on this matter. Thanks, Tom
    i7 8th Generation processor with a Quadro P2000 5GIG graphics card. 32GB of 2400 Ram. 1 SSD 256GB Hard Drive, 1 500GB Hard Drive & 1 2TB 7200 HHD
    My Mother Board is an Asus H370M -PLUS
    Edius 8 Workgroup Windows 10 Pro 64 bit. BenQ 32 inch 4K 10bit monitor.
    Tom Riccobono in New York City
    standuptommy.com
    The resolution drop down thing is only in Workgroup version. If you feel like you need it to avoid stuttering in playback, you should stick to the Workgroup version.
    If you prefer the new features in Edius 9 (as HDR), but cannot afford the Workgroup version, you most probably end up using the proxy mode if your hardware cannot playback your material smoothly.
    Intel Core i7-7820X ---- Noctua NH-D15S ---- MSI X299 GAMING M7 ACK ---- 64GB RAM 2666-15 Corsair Dominator Platinum ---- 500GB Samsung 960 EVO M.2 (system SSD) ---- 512GB Samsung 960 PRO M.2 (data SSD) ---- Aorus Nvidia GTX 1080 Ti ---- be quiet! SILENT BASE 600 Case ---- be quiet! Dark P. Pro P11 850W ---- Win10 Pro ---- Edius WG 8.53.2808
      Thank You Captain. That answers my question about 9. When you say edit in proxy mode, would you mind telling me what that means? Perhaps that is an option for me.
      standuptommy.com
        Proxy mode is a mode that lets Edius create lower quality proxy files to edit with. You then switch out of proxy mode when you are ready to export.
        In order for this to work simply have to add the proxy mode button to the timeline tool bar so you can switch modes.
        This is a feature that is available in the Edius 8 version you have so you can try it out before deciding if the upgrade to workgroup is necessary (it is a feature available in both pro and workgroup).
