Hi, I use Edius Workgroup 9 to make UHD videos. I always made a stereo soundtrack (2 channels) but I'd like to make a 5.1 audio system. How could I make the audio channel mapping for 5.1 sound? Do you have some pics to understand better? Thanks for some info.
Edius 9: how to make audio channel mapping for 5.1 sound?
CPU: Intel i9 7940X
SSD Drive:
(D) 1TB Samsung 960 EVO PCIe M.2 NVMeTags: None
You will need to decide which export format you will be using prior to setting up your desktop. I have my timeline setup for .wav export. I can change the channel map to export to .mp4 very easily. But, to get the file to re-import into Edius from a different program, I have to import it back into Edius as a .wav file. Setting it up as shown in the video will allow you to import the file back as an .mp4.
I usually master my 5.1 files into a single .wav file. The .wav AC3 setup order is different from the .mp4 setup.Jerry
I will make it the next days. Out of curiosity: when you export 5.1 sound from Edius timeline, then do you listen a really good sound or do you listen a better sound with 2 channels stereo?Last edited by Ulisse; 12-08-2018, 05:07 PM.A lonesome traveler looking for lost tribes around the world: https://www.youtube.com/channel/UCdv...DrZCaaw/videos
CPU: Intel i9 7940X
SSD Drive:
I monitor by 2 channel, but you can select and listen to each channel separately through a 2 channel system with Edius.Jerry
I don't think you'll have much fun as Edius creates incorrect 5.1 mapping. It is cumbersome and poor - work with something like Audition for correct results or invest in a professional DAW.
Good luck!
Paul :-)Edius Edits at: http://www.vimeo.com/user781619/videos
