Does EDIUS 9 Pro support EQUIRECTANGULAR picture format
  • Does EDIUS 9 Pro support EQUIRECTANGULAR picture format
    Hi,
    does anyone be able to tell me if the current EDIUS 9 Pro version enables users to :
    -import equirectangular pictures format (e.g. 16384x8192 px)
    -place it in the timeline
    -wrap it around a virtual sphere
    -apply on the clip effects as you want : Normal view, Fisheye view, Little Planet view ...
    -at the beginning of the clip : start somwhere then
    -at the end of the clip: end after a smooth 360° rotation
    -being able to make the clip fast played / trim the clip / etc.
    Thank you
    Hervé
    best regards
    Hervé
