Where to enter Soundsoap Autorization code
  • Where to enter Soundsoap Autorization code
    When I start Edius 4.5 Soundsoap pops up that:
    " The registration period has now expired...... "
    How can I enter the Autorization code which I received from Bias?
    Start button, program files, Bias, authorization manager....
      I have only version which came with Edius as a bonus.
      There is none folder " Start\Bias..." or "c:\Program files\Bias...."
      The only one is:
      C:\Program Files\Canopus\EDIUS4\PlugIn\VST\BIAS SoundSoap VST.dll
      Is it time limited version?
        Anton was talking about the Start menu, not the directory structure.
        However, if you go to C:\Program Files\BIAS, you should see a separate directory for the Authorization Manager. Run that, and you should be in business.
        One other complication is that the latest SoundSoap (V2.1.1) uses a different serial number format. If you go to the BIAS website and download the latest version, you'll have to issue yourself a new serial number to activate it. Use the serial number supplied with Edius, and the BIAS website will give you a new serial number that can be used for activation.
          i have the same problem!!
          Where i can enter the activation-code??? everytime this messagebox appears!
          No startmenu-item from bias
          No "BIAS"-directory in program files
          only one file: "BIAS SoundSoap VST.dll"
          where i can autorize it?
          please help!
            click the Start button at bottom left of your PC and follow it to the Bias authorization manager
