Upgrade from Edius Pro 3.61 to 4.51
  • Upgrade from Edius Pro 3.61 to 4.51
    Might be a dumb question but is the upgrade worth it? I've haven't had any problems with Pro 3 plus I like to still use Imaginate 2.
    Does Pro 4 support Imaginate 2?
    I'm a firm believer in that if a product does what you need it to do, and it works, and doesn't cause you any problems - why change it? But with that said, there is now a very large list of changes from 3.61 to 4.54, which you can preview here:
    And yes, Imaginate 2.0 is supported.
      Through the many years I've been associated with computers and computer software, I've come to believe that skipping major upgrades to a product you rely on is usually a mistake. Eventually you will want to upgrade and if you've let the product get too far ahead of you, it will be more painful than necessary. Just a general observation.
      Fred D
        I upgraded from the 3.xx to 4.54 just recently. I hadn't checked the Edius sight for about a year and had to do some catching up, but it was really worth it.
        Ken,
        Edius 5.12 2XOpteron 280s, K8WE, NX, SATA 1Tera, Radeon Extreme X850, 24" Dell LCD and some other 17" LCD, Pioneer BD-RW BDR-205(1.02),
        Sony Cams; FX1, FX1000, FXR-7.
        Owner - D&J Video Productions
