Primary Color Correction - key shortcut exposition
  • Primary Color Correction - key shortcut exposition
    Hi, do you have any way to speed up your work during color correction in edius? I was looking, but probably there is no option to assign a keyboard shortcut to the Primary Color Correction window? I care about the quick change of the clip's exposition / brightness. It would be great to be able to correct WB ...
    There is no speed up tip like you are looking for. The drag and drop nature if the plugins is the normal way that an NLE deals with this type of thing.
    If Edius had a dedicated colour correction mode that made it behave like a colour suilte, such as Resolve, Mistika, Baselight, etc, then the answer would be to engage that mode.
      Here, a quick window call would be useful ... just like the shortcut F7 calls the Layouter window ...
