I can't seem to find a way to normalize (keep the same audio level) an entire project. Is there a way to do this in 4.5+?
Normalizing Audio
Export the audio out to WAV. Then use Sound Forge or some other audio editors to normalise the audio. You will get a much better job that way than to do that within EDIUS.TingSern
Originally posted by 3chip View PostI can't seem to find a way to normalize (keep the same audio level) an entire project. Is there a way to do this in 4.5+?
Or export the audio to a audio package as has been suggested.Cheers,
Stuart.
You can use this VST : Classic Master Lmiter
Very helpfull and very low ressources
Perfect and free !
MarcSystem : W7 Ultimate - MB: Asus Z170 - I7 6700K - Ram 16 Go - SSD1 256 Go (OS/log) - SSD2 1To (rushes) - HDD 4To (save) - Nvidia Asus GTX970 - HDspark - Edius WG 9 - Vistitle 2.6 - Robuskey - Mercalli4 - Neat video - Ignite - Hitfilm4Pro - AV : Eset Nod32 - Others : Moniteur Sony 32-EX500 - Cam : Sony EX1-R - 2 x Sony PXW-X70 - 1 x Pana GH5
Edius in France
But as has already been pointed out - VST's are unstable in Edius - all the Classic range of great VST's cause very loud clicks on entry to the clip or clips onto which the VST has been applied.
This is probably the longest running and poorest Canopus/ Grass Valley unfixed issue that still remains in Edius. No attemps have been made to fix it, even though Soundsoap VST was bundled with Edius - and fails to work properly - one of the reasons Edius will never compete well with some of the more established NLE's.
Maybe by Edius 6 the VST thing will be sorted, but somehow I don't think audio is considered to be of importance by GV - if it was, it would have been fixed.
Happy New Year All
PaulEdius Edits at: http://www.vimeo.com/user781619/videos
AAF export the audio and video to Vegas 8 pro, and you get the project laid out much the same, easy to do all your audio tweaking that way - very fast to export, and you can have Vegas and Edius open at the same time without problems.
I can second that.Steve
I hope it will be there some time, soon i hope.
Feature Requests
JoiCam´s
And more
I would like to think Edius 5 would have surrond sound, key frames for all filters and maybe even a little bit better DVD authoring system from the timeline. I like Edius but the competiton has more features. It would be great if Thomson GV could make a real time noise reduction filter for Edius. That would blow away the competition. Audio is half the equation when editing video. I admit Edius still works best for me. You can not beat the RT of Edius with Final Cut Pro or Adobe Premiere Pro.
Sorry guys ... I see EDIUS more as a RT video editor rather than an audio editor. Go and get Sound Forge if you want a great audio editor ... putting more stuff into EDIUS makes it slower and bigger ... do you want to see code bloat? I rather have a lean and fast video editor that does its job blazingly fast ....TingSern
