titlemotion problem
  • titlemotion problem
    I Have V4.51, I Tried To Install Titlemotion Pro But I Get The Message Edius Not Found So I Installed V3.60 And It Worked Fine It Installed And Functions Well.
    In Addition To That Sound Soap Also Freezes My Computer When I Drop It On A Clip(v4.51)
    EDIUS 9.5 /Win 10 x64 Dell T5600 INTEL Xeon 16 core @2.66GHz 32GB RAM /NVIDIA GEFORCE GTX 1660TI, SSD SAMSUNG 500GB PRIMARY, WD 5.5TB STORAGE, 2x WD500GB ASSETS, heroglyph 4.0, Sony AVCHD cam, Canon DSLRs.
    Sys 2: Asus ROG G75series
    old Title Motion Pro won't detect Edius 4.0 or 4.5 try to install newer version of Title Motion Pro
      I don't know if this will help or not but..... when I upgraded from 3.5 all the way to 4.54 I uninstalled 3.5 with the Edius un installer. Then I put in the 4.0 upgrade disk. When I put in the TMP disk it asked for my 3.5 TMP disk. After that TMP went forward flawlessly.
      You might go back and start over .
      AS a result of all the help I get on the forum all my machines are now up and running 4.54 and ready for the new year.
      I am always one click from disaster or one click from success
      Good luck
      Ronnie
      Ronnie Martin
      Kato Video Productions
        finally got it
        Wounderfully i tried what you guys suggested and it worker perfect, thanks guys for your help.
