Can anyone tell me how to add a transition to the front of a clip with no other clips before it? I am running Edius 4.54
Transition to front of clip
Just drag it on to the clip.Steve
Not exactly. I went over the help again and found the solution, you drag it to the mix area below the clip. If you drag it to the clip anywhere it will drop on the area between the clips.
Thanks for the input.Computer
Case Antec P180 - MB Intel 975XBX2 - CPU Intel Q6600
Memory 4 gig DDR2 800 - 2 Drives SATA 300 + 500
Video Card Nvidia 8800 GTS 320
