Lost my title motion pro on up grade
  • Lost my title motion pro on up grade
    Finally, I have decided to try and update all my machines and started with one of the Storm Machines running solidly on 3.5.
    Logic is, if I can get this one up and running then proceed to the NX Machines.
    I followed the uninstall and install directions.
    My installation was an upgrade to 4.0 from 3.5
    I followed the directions when installing TMP by using the TMP disk from 3.5when prompted.
    Then I opened an old project. When I click on a title from the old project TMP comes up and works fine. However, when I try and create a new title Quick Titler is the default titler.
    How do I make TMP the default titler?
    Sorry about the dumb question. TMP has been my default titler on all the Edius versions.
    Ronnie
    Ronnie Martin
    Kato Video Productions
    go to application settings and select TmPro as default titler
      Thanks Anton
      Sorry to be so dumb... All of my machines have been turn keys and they all had the default set for me.
      I actually found TMP under the matt and color bar pull down.
      Now that 4.0 is running, I can bring it up to 4.54.
      Ronnie
      Ronnie Martin
        and hopefully to 4.6 soon
          Ronnie you can set the default titler in SETTINGS > APPLICATION SETTINGS > APPLICATION
          Default titler is about half way down the page.
            Thanks guys I got the TMP going now.
            On the NX machine that has pro coder 2 on it I lost the procoder 2 plugin when printing to file. PCE express is there.
            Ronnie
            Ronnie Martin
              you may need to upgrade to ProCoder 3 in order to work with E4????
                I forgot there is a procoder patch.
                Ronnie
                Ronnie Martin
                  I have them all up and running now. Thanks for all your help
                  Ronnie
                  Ronnie Martin
                    Yep. PC2 works fine with Edius 4.xx with the patch that allows Edius to have it in its export list.
