Edius Pro 9 / DNxHD mxf import
  • Edius Pro 9 / DNxHD mxf import
    Is it possible to import and edit dnxhd mxf in Edius Pro 9?
    I know the quicktime solution, but I need to edit mxf. I installed Avids dnxhd codecs, but Edius Pro still can not import. Edius says "codec type not supported".
    Thanks!
    Thanks!
    The free avid codecs are a quicktime plugin so the DNxHD has to be quicktime wrapped. DNxHD that is MXF wrapped requires native support in Edius. This is an optional $499 for Edius pro. https://www.videoguys.com/grass-vall...hd-option.html
    This is included in Edius WG
      The DnxHD mxf feature for the Pro version makes Edius able to export Type5 AAF for Media Composer?
      I know the Workgroup version can export Type5 AAF, the question is about the Pro version.
      Thanks for Your help!
        Your original question was about editing not aaf export. I don't know if this will allow for the aaf exports, but I would hazard a guess that it will if pro has aaf export capabilities already.
        However, if you are considering purchasing this option, for what it costs, you might be better off considering a pro to workgroup update instead, as you will get more than just mxf support.
